-   Tripod Sticks & Heads (https://www.dvinfo.net/forum/tripod-sticks-heads/)
-   -   Bogen 516 problem (https://www.dvinfo.net/forum/tripod-sticks-heads/55422-bogen-516-problem.html)
Jim Herman December 2nd, 2005 07:29 PM
Bogen 516 problem
I just rented a Bogen 516 head and there is no tension at all when I pan. I get drag for up and down motion but not for side to side. The screws underneath the head are tight so I'm assuming they rented me a broken tripod head. Is there anything I can do to fix the head because there is no time for me to run back to the rental place.
-Jim
Don Bloom December 2nd, 2005 10:57 PM
Did you tighten the drag knob located under the base of the mounting mechanism? Clockwise will tighten it. Give it a try. If that still doesn't fix it then yeah sounds like the head could be kaput!
Don
