Remote controlled head
looking for a remote controlled pan-tilt head than can handle 10lbs or so of camera (Pana AJ-PX270), smooth moves, connection to controller via ethernet. we will convert LAN to fiber and control from some distance away. what's out there?
Re: Remote controlled head
The Varizoom MC100 can do the trick. It currently has lemo connectors for the pan/tilt, but I'm sure the connectors can be swapped out. I have a unit, I was ready to change the connectors myself.
VariZoom VZ-MC100 Pan and Tilt Control System VZ-MC100 B&H Photo |
Not ethernet, won't work for my purposes. Changing the connector doesn't make it ethernet...in this case some distance is greater than 1000 feet
