-   Tripod Sticks & Heads (https://www.dvinfo.net/forum/tripod-sticks-heads/)
-   -   75mm head on Sachtler Eng 2 100mm tripod. (https://www.dvinfo.net/forum/tripod-sticks-heads/524848-75mm-head-sachtler-eng-2-100mm-tripod.html)
Owen Kilgour September 9th, 2014 07:56 AM
Will a 75mm head work on a Sachtler Eng 2 100mm tripod with an adapter like this, http://www.bhphotovideo.com/c/product/1046986-REG/e_image_ei_a17_e_image_100mm_to_75mm.html ?
The Sachtler version is $200 which seems a lot.
Zexun Tan September 9th, 2014 10:24 AM
Re: 75mm head on Sachtler Eng 2 100mm tripod.
No reason why it won't. People will bring up that the tie-down clamp knob must be able to clear the tripod legs during fold-up etc but for a 100mm tripod I doubt that's a problem.
James Kuhn October 1st, 2014 10:18 AM
Owen Kilgour...I use a 100mm to 75mm adapter plate with a Sachtler FSB-8 fluid head and a Sachtler CF-100ENG HD 2 CF Carbon-Fiber Tripod. I also use the same 'adapter plate' with a Gitzo G1325, Mk II Carbon-Fiber Tripod to mount the FSB-8.
I've found all iterations of this set-up to be solid and stable.
Best regards,
J.
Owen Kilgour October 2nd, 2014 01:59 AM
James, thanks for the info!
Which adapter are you using?
James Kuhn October 2nd, 2014 10:34 AM
Owen Kilgour....I believe I purchased this kit from B&H - Sachtler Adapter 75/100 75mm Ball Base to 100mm Bowl Adapter B&H # SA3906 ■ Mfr # 3906.
It's expensive (Sachtler's name, right?), but it includes a modified Tie-down knob and bolt. The piece is well machined with precise tolerances, just like everything Sachtler makes.
I purchased the adapter with the Sachtler CF-100ENG HD 2 CF Carbon-Fiber Tripod. I didn't have a 100mm tripod head, yet, and wanted to be able to use the tripod with my Sachtler FSB-8.
It looks a little funny with the FSB-8 mounted, but it works fine.
I hope this helps.
J.
Craig Chartier October 4th, 2014 03:58 PM
Benro also makes a 100mm to 75mm adapter ring. might be cheaper.
Owen Kilgour October 5th, 2014 02:23 AM
There are several much cheaper options, i just don't have a way of verifying if they will work. Also, i may need the longer tie down bolt that comes with the Sachtler adaptor.
