I am having problems with the vertical pan with the Libec LS-22:
Hello,
I got the Libec LS-22 tripod. It pans great horizontally but vertically I am having some issues. When I pan vertically the head sometimes catches and switches the balance switch to ON. Or if the balance switch is ON, it snaps for a second. Maybe I am not understanding the balance switch properly. The manual does not do a good job of explaining it either. How do you use the balance switch. I would like to be able to pan smoothly without the head catching for a second. It only happens in the vertical setting. Any tips? suggestions? Thanks, Simon |
Strange, I am trying to replicate the problem and I can't! :(
grrrrr! Seems fine. It worked as soon as I wrote the message on this forum. ;) Simon |
| All times are GMT -6. The time now is 04:20 PM. |
