-   Tripod Sticks & Heads (https://www.dvinfo.net/forum/tripod-sticks-heads/)
-   -   change head on Bogen 3040? (https://www.dvinfo.net/forum/tripod-sticks-heads/43364-change-head-bogen-3040-a.html)
Celia Cotelo April 21st, 2005 06:55 PM
Hi
I inherited bogen tripod 3040 with a fluid head and another head on a long arm. I want to change the fluid head that's already mounted to this one and can't figure out how.
Does anyone know?
Marc Schotland April 29th, 2005 09:57 AM
Hopefully you've been able to figure out how to remove your head in the past week, but if not, can you post the model number of the head you have mounted on the tripod. I also don't recognize the tripod model number.
In most cases you will need to unscrew the three set-screws that fix the head to the tripod. These three screws are located underneath the column plate. Raise the column and look under the round plate where your head is attached. Unscrew these and turn (counter-clockwise) your head and it should come off the tripod. This all depends on the head and tripod type being what we term 'flat-based'.
Post the model numbers I mention above and I'll try to guide you through if you're still in need of help.
Marc Schotland
Manfrotto
