5d mkii portable tripod suggestions, please?
Hi, I am looking for some portable tripod suggestions, right now I am liking the idea of this combo:
Gitzo GT1541T legs Gitzo G2180 head Thoughts? Yay? Nay? Any thoughts on the Benro C-069? This is of course not an inexpensive combo, so if anyone has any suggestions for a duo that would do almost as good (or better) at a better/comparable price point that would be nice. I won't be mounting anything longer than 200mm, no battery grip, just a 5d a lens and sometimes a glidetrack compact or rails/ff. Maybe a mic, h4, or monitor once in awhile too. Top notch pans are not crucial to me, as, in general, I prefer static shots anyway, but the ability to pan decently would be swell! I have access to heavier tripods, I just want something of my own that I don't dread carrying around as I travel primarily on foot. Thanks! |
Seeing as you are already considering Gitzo, you really should consider stepping up to a bit higher level of leg as recommended by Jack Walker. Only a bit more money but probably a lot stiffer and more suited to video work with its 75mm bowl.
Gitzo | GT3531LSV Systematic 6X Carbon Fiber Tripod | GT3531LSV As far as that Gitzo head goes, I have no experience but I sincerely doubt it is suited for anything more than holding the camera in one spot. If that is all you want to do then I am sure it will work fine but it will not fit a 75mm bowl without an adapter. A bowl is very important to get level setup without a lot of hassle. When you realize it is far too simple a head to do any kind of good video work you will not have spent too much money and will at least have good legs to start with. If you want to step up a bit on the head, and live with its shortcomings then perhaps this would be a good start for you: Libec | H38 Professional Fluid Head | H38 | B&H Photo Video EDIT: maybe this head would be more suitable for the weight you want to run:http://www.bhphotovideo.com/c/produc....html#features The 38 has a fixed counterbalance that is too strong. I have no direct experience with the Libec head but a few people have started with it and it is probably a big step up from that Gitzo for anything video. I find it hard to make recommendations for cheap gear but the tripod is good, and the Libec head is probably better than your expectations and only a bit more for the whole package that you were looking at. For serious HD video work, it doesn't matter what the camera, you need to spend $1400+ for a tripod system. Even then that might be too low. Just say NO to Benro. I have seen their products and although they look like good bang for the buck, the break easily and have some pretty rough spots in the construction that you can't see. |
I had a similar style set of legs and I hate them. I will only ever use snap lock style release and lock. The screw type take forever to adjust. |
| All times are GMT -6. The time now is 12:40 PM. |
