How is the Miller Solo DV20 in windy conditions?
Interested in this tripod for outdoor work, it can be quite windy our here. How does this tripod do outside?
Hi John................
This is getting very monotonous....................
http://www.dvinfo.net/conf/tripod-st...r-solo-vj.html CS |
I also try to find out more about it.
Some people like it very much: Philip Bloom Blog Archive Miller DS20 Tripod Review Official Tripod F.A.Q's - Page 4 - DVXuser.com -- The online community for filmmaking Some like Chris from above donīt :) I guess i will have to try it out for myself. |
The DS10 is brilliant. Ive done work in 60kt wind and its been fine. But then, I never let go of the thing anyway.
Mind you, I did get blown over once. tripod, camera and me, the wind was that strong. Ben Oh, and I would'nt say this is monotonous, as these questions do pop up from time to time and its quicker to ask than do a search. (My 2.2c worth, including tax) |
In our area we have several wind energy farms, so we get pretty consistent wind and sometimes high wind. |
Also I found a lot of the links were to discontinued products. |
I have used the Solo 20 setup for a while now and can say it is not up to the task of good HD video for many purposes. It is good for certain shots and low level shots due to its leg design.
The legs do wind up a bit and it really shows near long end of the zoom range of the stock lens. Anything longer focal length and it is not really usable for anything other than lock down shots in still or light air movement. Even with the stock lens it needs this care to some extent depending on the focal length in use. The head is balanced just right for the EX3 on the low spring setting. The fluid motion is OK for very carefully manipulated moves, but it has to be treated with such care it gets in the way of efficient work. It needs higher drag for smoother moves but the drag is not adjustable. There is added friction that can be added but it adds mechanical friction and not additional fluid resistance so the added drag adds all the bad things one wants to avoid by buying a proper fluid head. The pan and tilt locks are advertised as movement free because they are claimed to be disc brakes. They are in a fashion in that the locking screw jams against a disc but the rotation of the locking screw still causes motion on lock and unlock. Perhaps a small slug placed in front of the locking screw face could make this problem go away. The DV20 Solo setup is not suited to everyday use. It has it's place in being compact and light when that is the most important criteria for a shoot such as minimal airline carry or getting a tripod into a place on a long hike or climb. Used with kid gloves, it can be forced into service but it sure is frustrating when you need to get the shot done now. |
| All times are GMT -6. The time now is 09:33 PM. |
