-   Tripod Sticks & Heads (https://www.dvinfo.net/forum/tripod-sticks-heads/)
-   -   OK, can you name this tripod? (https://www.dvinfo.net/forum/tripod-sticks-heads/144514-ok-can-you-name-tripod.html)
Derrick DeWilde February 24th, 2009 11:09 AM
1 Attachment(s)
I have a picture of this tripod...it is a manfrotto 3433 head, but I cannot figure out which tripod this is. Do you know?
Adam Gold February 24th, 2009 01:59 PM
The legs look like the Manfrotto 3046/3246. On mine it actually shows the name and number on the center column...
Derrick DeWilde February 24th, 2009 04:31 PM
That is where I was at...it is at an auction and I can't view it live cause it is out of state. Trying to make sure I bid correctly! You know what i mean!
Chris Leong February 24th, 2009 05:33 PM
Yeah, what Adam said. It's a regular Bogen/Manfrotto tripod with a Bogen/Manfrotto vertical shot attachment pillar added.
I know because I have one (the pillar, not the tripod).
Basically it's an adjustable 90 degree adaptor. You unscrew the head off the tripod, screw the pillar onto the tripod, screw the head onto the pillar. Vertical shot ability, no problems.
The adjustability is that the pillar can be adjusted so the tripod head can be closer or further away from the tripod base, and also the cylindrical pillar can be pivoted within its mount.
So think of it as a regular tripod with head plus a 90 degree adaptor arm, because that's what it is.
Cheers
Chris
Adam Gold February 25th, 2009 07:27 PM
Can't you just ask the seller?
