-   Tripod Sticks & Heads (https://www.dvinfo.net/forum/tripod-sticks-heads/)
-   -   building spreaders-need parts (https://www.dvinfo.net/forum/tripod-sticks-heads/117543-building-spreaders-need-parts.html)
Samuel Hinterlang March 22nd, 2008 01:15 AM
I built a tripod, sort of. I used a survey tripod for the legs and adapted it to fit a head. I needed something to hold my jib and didn't want to spend over $1000 just for that one purpose.
Now I need to make a set of spreaders for the thing. I know how I'll do it. But the one part I need, I don't know what to call it to find it.
I need to find metal bars that have a slot down the middle. You know, like what most spreaders have.
Pounding at google for two hours now with no answer get a bit frustrating.
Thanks for any help on this.
Alan Craig March 22nd, 2008 01:41 AM
I don't know where you would buy such a piece of aluminium because they would be specially manufactured for tripod makers but a cheap solution might be to use some strong cord tied from leg to leg to stop them spreading.
Alan
Samuel Hinterlang March 22nd, 2008 01:48 AM
Spreading isn't the actual problem, strangely enough. The real problem is being able to get the whole thing level quickly. I want to mark off points so that all the legs will be evenly spread.
Cheap isn't really a huge requirement either, just not expensive is the key. I'd buy some spreaders if I knew they'd work with my feet, but I don't wanna waist $200 on a guess from a picture.
My big thing is finding what that type of metal is called.
