-   Tripod Sticks & Heads (https://www.dvinfo.net/forum/tripod-sticks-heads/)
-   -   Mounting a Tripod Head on a Lightstand? (https://www.dvinfo.net/forum/tripod-sticks-heads/100999-mounting-tripod-head-lightstand.html)
Travis Cossel August 9th, 2007 05:37 PM
I've never purchased JUST a tripod head, but I'd like to attach one to a tall lightstand for a high-angle unmanned camera shot. My question is, can I just place a tripod head on the lightstand and tighten it down?
Are there special connections or what?
Chris Soucy August 9th, 2007 07:27 PM
Hi Travis............
From memory all "flat bottomed" heads have a hole to take a 3/8" bolt. If your light stand has a suitable bolt you should have no worries. However, something in the back of my mind seems to think light stands are fitted with 1/4" bolt threads on top, so you may need a 1/4" to 3/8" adapter.
Given the all up weight of a pan/ tilt head plus camera I'd make sure those legs were well and trully sand bagged tho' - could be an expensive ol' "whoops" otherwise.
CS
Travis Cossel August 10th, 2007 01:32 PM
Thanks for the advice, Chris!
