What do u call this??
Hi,
What do you call that thing which is at the start of old cartoons/films, which is like a circular animation which countsdown from 5 (or 10?), and each number is revealed with a beep by a circular wipe? whats that called?! and is there a plugin for Vegas or Premiere which does it? Thanks, Josef |
I think it's called a 2pop.
thanks, but are you sure? I coudnt find anything suggesting it was a 2pop when I searched "2pop" and "2 pop" on the web...maybe it has a more general name?
I'm pretty sure, but yeah it's hard to google, unless you go something like "2 pop film countdown"
http://www.sweetwater.com/expert-cen...ssary/t--2-pop Aaron |
Well, it's just an ordinary leader isn't it? (SMPTE probably)
They were even used in TV for allowing telecine machines to get up to speed - same as the VT clock, which you can still see these days, even though most playback decks will start almost instantaneously - so they're basically there as an ident. Robin |
sounds like ur right indeed. thanks for the help. I ended up making my own using the "clock wipe" transition on Vegas...sounds like i did it a bit wrong though reading that desription!
Or simply countdown leader
| All times are GMT -6. The time now is 04:00 AM. |
