Broadcast Compression getting worse?
So, it seems to me that even the most watched programs are being compressed heavily.
I was watching Mad Men and was just amazed at the poor quality of the image. Anyone noticing a degradation of broadcast standards? This is based on Comcast South Florida. OnDemand is even worse. |
Re: Broadcast Compression getting worse?
Cable is notorious for re-compression. Started with MPEG-2 at around 12Mbps and now we have H.264 streams at even lower bitrates being delivered on Cable and FTTH services. The least amount of accessible compression comes from ATSC over-the-air.
However, in Canada, even ATSC is not a guarantee for the lowest amount of compression as simsubbed programming usually takes a US ATSC signal and recompresses it for Canadian airing, and that is then passed through cable. So if you're watching a live show like American Idol on CTV, it's taking an American 720p60 ATSC signal, converting it to 1080i, then recompressing it first to ATSC on CTV, then again if it's going to cable. The absolute worst case scenario is the CBC. They take a 1080i source and downconvert it to 720p60 for ATSC, but then cable re-upconverts it to 1080i from 1280x540 per frame. You get both de-interlacing and macroblocking artifacts. |
Boys, you ain't seen nothin' til you've seen the "This" network.
If you want a quality signal, your best bet is OTA. I've found that the actual broadcast stations (at least in my local area) are decently responsible and are interested in signal quality. Locally we prevailed (me and a bunch of other viewers) on the local NBC affiliate to rob bits from their subchannels to improve the bit rate of their main channel during the last winter olympics. They did, and the signal improved rather markedly. For the duration of the olympics anyway. Sigh... I've also been known to hop on the station engineers for more bit rate during basketball games. A panning camera and a checked hardwood basketball floor can make complete mush without sufficient bit-rate. The engineers know this, and now that they've had a couple of years of phone calls about it they seem to ride bit-rate the same way I ride levels on a field mixer -- they know to increase bit-rates during the NCAAs and viewers don't have to call them now. But the biggest problem I've seen with cable is their desire to crush blacks. It's almost as if they think everything below 15 IRE is free bits they can steal. Which they do, visual quality be damned. OTA is higher quality, and its free. And I can get most of the programs from the cable channels on DVD or better yet, blu-ray (a year later, I'll grant you that, but what's the rush?). On an optimistic note, people can't buy old analog 4:3 SDTVs anymore. So as TVs age out and are replaced, people have to buy digital 16:9 HDTVs. And those people are seeing the same thing you are. And at least some of them will complain about it like you are. When sufficient complaints hit the local Utility Commissions maybe some pressure will be brought to bear on the monopoly cable providers to improve their signal quality. We can only hope. |
Very interesting.
So, if they bump up the bitrate on a specific program or channel, they have to take it from somewhere else right? Whether it be from other channels, number of channels, or internet service bandwidth? |
Hey Mark,
They need to clear space for the crucial programming like 'Ice Road Swamp Loggers' :) I have been with DirecTV from the beginning of the HD boom and think their image is very good. I have seen the Dish Netowrk's image and it is pretty compressed. I would not be surprised to see the trend though, especially if they try to get some more interactive stuff going. Maybe when more fibre gets to homes they will have more bandwidth to play with. |
FTTH will introduce H.264 delivery, which will increase compression further as they cram more channels in that bandwidth.
H.264 will also increase latency for interactive live broadcasts... 4DTV C-band Satellite if it still exists would be the least amount compression since they're taking master feeds from the networks. Sadly, that has gone extinct. https://en.wikipedia.org/wiki/4DTV |
| All times are GMT -6. The time now is 01:21 AM. |
