What are the basics for Film-Looking DV?
I have a GL-1. I shoot with a shutter speed of 1/60 in the frame mode. This produces pretty good results.
Recently i discovered something called "De-interlacing". I don't know a whole lot about it. But I'm wondering, is this something I should do in addition to what I'm already doing (shooting 1/60, in frame mode)? If I'm shooting at a shutter speed of 1/60, what is my GL-1 ACTUALLY captureing at? 60 frames per second or something else? (29.7 probably)? Sorry, I'm easily confused. Also, in post production should I bother even trying to reduce the frame speed down even further, like to 24, or is simply doing what I'm already doing good enough? curious... |
My experience with deinterlaced video on tv, tends to make the whole image jerky. Likewise, reducing the 30fps video down seems to lose frame to frame quality. I have been experimenting with achieving a film quality, by merely reducing the chroma level a little, and adding the slightest bit of gaussian blur.
This softens the overall picture, and removes the harsh and sharp video look. You can then play with the black levels and contrast. It has a remarkable effect. |
Is adjusting the Chroma something you would do in post, along with guassian blur? I have FCP.
Thanks... If you were shooting with my GL-1, would you continue to shoot in frame mode then? And can you even de-interlace footage shot in frame mode? |
Frame mode is a process of blending fields within the camera, in an abstract way the footage you have is already de-interlaced.
Film look is more about good lighting, being careful about what you shoot, and tweeking the colour and gamma settings in post. There is a good article mirror here on dvinfo, i can't remember the url do a search on the main site under articles it has some good tips. zac |
I think these are the articles to which Kermie refers.
Richard- Chroma is something you do in post, akin to color correction. The same with gaussian blur-it is a filter in most NLEs and Photoshop. As far as frame mode, I always had problems with severe blurring with motion, so I keep it in standard mode. But that is me.
Lighting your sets like a film production would will also go a long way in helping.
This is the THE big question... I know Chris had said they were talking about compiling a lot of the information in posts to make a FAQ or Tips List but I don't think anything came of that.
Number One Tip to make video look like film above every other: Light and Shoot it like film If you spend the time working on your shots and lighting it like it was a "real film" production you have made it 80% home. Beyond that there are thousands of tips and discussions here--- hate to say "do a search" but I will. You could spend days here reading all the fantastic suggestions and advice people have offered. |
It kind of goes without saying, that every scene needs to be lit correctly, regardless of film or video. If it isn't lit well, it doesn't matter what look you are going for, you won't have a decent image.
I've shot stuff that I knew I had ENOUGH light to get a good picture but it's not like I "lit" the scene. I got the shot and that's all I was going for. I wasn't trying to set a tone, set a mood or catch the textures on the wall behind someone. I was just making sure there was enough light but not too much light. A great expression someone came up with was "Painting with light". Lighting is part of FILMCRAFT. Without Filmcraft whether you're shooting 8mm video or 35mm film it will look like crap. Lighting is an art. For film especially... It's like setting up shots and knowing how to shoot a scene. Knowing what will convey the message you are trying to get across.... |
"Film look" is not just a matter of rendering video for film impression. Actually, I think overall control of the frame's appearance and content is the core objective. This means
In the end, what really separates the professional from the amateur in the viewer's eyes, whether film or video is the medium, is the control of the frame and how well it frees the viewer from distractions and leads him/her through the story in a thoughtful way. |
Richard,
It can be confusing indeed. Our "consumer" cameras operate at only one FRAME rate which is 29.97 fps for NTSC (which is called 30 fps) and 25 fps for PAL. When you are shooting interlaced these frames are devided into two fields and you get 59,94 (60) FIELDS per second and 50 fields per second. What you are referring to is the shutter speed which controls more how the image looks. I don't know how other to explain this without getting all technical.... Perhaps someone else can enlighten you more on this point |
Ken Tanaka wrote:
"making sure that any movement of the camera is made in a deliberate, controlled and purposeful manner." Great point Ken. This seems to be the second most (lighting being first) important aspect of that je ne sais quoi which seperates film from video. Stereotypically, video is marked by a more free floating, jittery, "hand held" look, resultant from countless home movies, and relative small size and weight, whereas a film camera is a big, unwieldy contraption, with lots of weight, encumbering size, and very likely locked down to an even larger object of device. Even a relatively small camera, like a Bolex H16 is still quite a bit heavier with just one mag of film, than your average prosumer video camera. What this all means is that if you were to treat your feather weight video camera, with the same approach you would a stationary film camera, you would go a long way in deciphering the kind of forethought that would go into staging and composing the frame as it would be film. Too often the urge is to pick of the video camera and begin to "experiment." If you pretend that there really is film in your camera, that it costs $40 per 3 minutes, and that you won't really know what it will look until a weel later, it is surprising how much more precious each shot becomes. |
Howdy from Texas,
<< I know Chris had said they were talking about compiling a lot of the information in posts to make a FAQ or Tips List but I don't think anything came of that. >> Actually we are going forward with this, and there's one in place right now in the Taking Care of Business forum. More on the way for all the other areas including this one, but it will be a somewhat lengthy process. |
| All times are GMT -6. The time now is 09:43 PM. |
