-   Techniques for Independent Production (https://www.dvinfo.net/forum/techniques-independent-production/)
-   -   What is the best looking 60i to 24p conversion software out there? (https://www.dvinfo.net/forum/techniques-independent-production/77194-what-best-looking-60i-24p-conversion-software-out-there.html)
James A. Davis October 10th, 2006 08:08 AM
Is it Magic Bullet? Is it Vegas? Is it DVFilmmaker? This topic has been brought up before but what is the definitive answer by those who have used all of the different 24p conversion programs. Which one looks the closest to a true 24p camera?
Ben Winter October 10th, 2006 09:55 AM
I've tried all except Magic Bullet and I love DVFilm Maker a lot. The conversion is fast and you hardly lose any resolution. That, and it's not even expensive! You can see an 18-second sample clip here:
http://blog.thelifeguardmovie.com/up...poolshoot1.wmv
And a collage of sample clips from the same movie here:
http://www.frozenphoenixproductions....estHD_480p.mov
This is Sony FX1 footage 60i to 24p.
John C. Chu October 10th, 2006 10:01 AM
I love DVFilmmaker...and on a PowerMac G5---it positively flies.
[Make sure you get all the free latest updates].
You can download a fully working demo to try out[it just watermarks your footage] but I think you'll be very pleased with the results.
You can also "letterbox" or crop your footage if desired---but if you are processing anamorphic footage--leave setttings off.
My home movies of my nieces have never looked this good :-)
Riley Harmon October 10th, 2006 11:51 AM
mpeg stream clip, free
James A. Davis October 10th, 2006 01:23 PM
I already have DV Filmmaker
I have DVFilmmaker already and it does a great job. I just wanted to know from someone whos used other conversion software as well as Filmmaker.
Ali Husain October 11th, 2006 04:53 AM
sony vegas with a supersampling envelope set to 2. it looks MUCH better than w/no envelope. the test on the website above didnt' do this for the vegas runs.
Steven Bills October 25th, 2006 04:19 PM
How do you apply a supersampling envelope in Vegas 7?
Alex Thames October 31st, 2006 05:38 PM
What is supersampling?
Bennis Hahn October 31st, 2006 06:46 PM
to set the envelope, press ctrl+shift+b to display the video bus track and then right-click the track and insert>envelope>video super-sampling
Phil Bloom November 1st, 2006 04:47 AM
depends on what platform you have...
Nattress plug in for FCP yields lovely results...
On Avid I have found Speedramp by 3prong to be exceptional.
Both the above do a lovely smart blend to minimize those jagged edges.
Joshua Provost November 8th, 2006 02:26 PM
Their methodology was to use default settings on all the products. They didn't tweak each one to get the best results possible.
Check out some of my previous posts on the topic (here and here). Magic Bullet produces some great stills, but there other factors to consider. Vegas does a surprisingly good job, but it's a full interpolation, so it may come out very smooth, but a bit soft (and can produce double/triple images if you don't use just the right settings). Maker takes the simplest and fastest approach of all of the products.
Frank Ladner November 15th, 2006 11:10 AM
James - I also wanted to mention some tools by http://www.revisionfx.com/.
Twixtor and FieldsKit for After Effects are both excellent. I have done many 60i to 24p conversion with them.
I have a sample here:
http://70.147.193.182:81/mwtest/
The file is "MicrowaxAdapter_shot_02_24p_720x480.avi"
This was from back when I was experimenting with 35mm microwax adapters, so the 720x480 footage had to be uncompressed, per the requirements of other adapter builders. :) It's a LARGE file on a slow DSL upstream, so it may take a bit to download.
Shot on a Canon GL2 in frame mode and converted with Twixtor to 24p.
