-   Techniques for Independent Production (https://www.dvinfo.net/forum/techniques-independent-production/)
-   -   First shoot ever! (https://www.dvinfo.net/forum/techniques-independent-production/61655-first-shoot-ever.html)
Raji Barbir February 27th, 2006 11:59 AM
First shoot ever!
Hey everyone,
I'm finally going to get started on a short film in the coming months. Since this will be my first time with actors other than family, i wonder if i'm missing something i should be planning for...
Right now i'm just planning on finding actors and securing the locations (2 in all, the third is my house). I'll also have to plan for some snacks and meals.
Am i missing anything else? Is there anything else i should think about or consider?
Thanks.
Raji
Emre Safak February 27th, 2006 12:17 PM
Unless you are a film student, I advise you to read up! The more you know, the more relaxed you will be on the shoot. People under you will do better if you project confidence. Any specific questions?
Dylan Couper February 27th, 2006 12:20 PM
Originally Posted by Raji Barbir
Hey everyone,
Yes, lots! Don't even know where to start, but most things you won't come upon until it is almost too late. Maybe you should get a producer with some experience to help you, but on the other hand, sometimes it's best to learn lessons on your own.
Raji Barbir February 27th, 2006 12:33 PM
I'm missing that much? like what? dammit... ok so what should i read up on? are there any other threads on DVinfo that i should look up?
I feel that i should have mentionned the following; the film is going to be a VERY small production. Total running length should be around 10-15 minutes, the actors aren't getting payed and i'm the only crew member. I'll be doing all the pre-production and post-production work (except maybe the music but i'll probably end up doing that too).
Emre Safak February 27th, 2006 12:49 PM
Hold it right there! You don't want to do this alone. Be sure to get some help. How are you going to hold the boom if you are manning the camera?
Raji Barbir February 27th, 2006 12:54 PM
i was planning on either using the onboard mic from the XL2 or carefully concealing the wireless Sennheiser G2 i just got for weddings.
Cole McDonald February 27th, 2006 02:35 PM
Go For It! Plan your shoot to the best of your ability, ask lots of questions here...pick and choose the advice you take from it. Make mistakes, get dirty! Learn from those mistakes for the next shoot! Don't not shoot just because you haven't done it before, just go for it.
Here's some learning that I did:
http://www.yafiunderground.com/AJ/howto.html
Andy Graham February 27th, 2006 04:15 PM
I agree....you should at least get somebody to help you shift all your gear around.
Also I wouldn't use the on board mic...there not good enough. The radio mic will be ok if it is secured properly although IMO the sound off a boom is alot more natural.
Other than that like Cole said go for it.
Andy.
Jean-Francois Robichaud February 27th, 2006 05:04 PM
If possible, get somebody to assist you. That person can help you set up, write down the shots, keep track of continuity, etc. It's a lot easier that way and gives you more freedom to deal with the actors.
Good luck on your shoot. My own experience with actors, as opposed to friends, is that they are a lot more committed. The same goes for crew.
Raji Barbir February 27th, 2006 05:23 PM
thanks everyone! I'm probably going to have to do with what i've got, which isn't much, but i really need practice and i wanna get going, so i'll work with what i've got sound-wise and cleanup in Audition if i need to. I'll do my best to manage without a crew either. If nothing else, the difficulties i'll face will teach me a couple of lessons, such as "you should really listen to people's advice when you ask for it" :D
i'm not sure if i should start a new thread for this next question, so i'll just ask it right in here.
Obviously i'm going to need to let potential actors read the script for me in front of the camera so i can see how they perform. The way i envision this, is that when the actors come in, i'd point to a page in the script and say "read this from here to here" and then push record. Repeat for all actors, send them home and then call them back if they fit the part.
How do i go about showing people my script without worrying about possible "theft" or whatever? How is this normally done? Do i just let them do a cold read like what i mentionned in the last paragraph?
Emre Safak February 27th, 2006 05:34 PM
Another reason why you need help. You need someone for them to read the script against. Otherwise they will be delivering a monolog. You want to see how they will respond to another actor. Maybe they can't?
Theft is definitely not a problem at your stage! Just give them the section you want them to perform (called a "side"), if you are worried. With a short film, you might as well send them the whole thing, since it's not that long anyway. Cold readings are cruel!
Dylan Pank February 28th, 2006 05:04 AM
Basically, you don't worry about it, it's not an issue. No-one is stealing 10-15 minute scripts. Anyway, if you're really concerned about it register the script. But in 15 years of filmmaking I have NEVER heard of a short film script being "stolen".
Maybe people will steal an idea, but ideas are not copyright-able, and nothing that can often be done about it. If I were you I'd show your script to as many people as possible. This thing about script ideas being "stolen" come up a lot with my students. Believe me, it doesn't happen.
Heath Vinyard February 28th, 2006 09:37 AM
Hey Raji.
For your audition questions:
First off, get a second person to sit with you and read with the actors. You'll thank yourself for this later.
Second, if you're worried about theft, just go to the WGA website and register it. It's only $20 and that's good peace of mind if you're worried.
Third, I would provide them with the entire script AND 1-3 pages of sides for them to read from for each character. I like to see actors come in and KNOW the material and have had the chance to work with it. You'll get better auditions this way, and you won't be wasting your time.
Good idea on the recording. Sometimes your mind plays tricks on you that can't hide from tape.
Good luck with it.
Heath McKnight February 28th, 2006 02:17 PM
My advice is simple:
1. Rehearse.
2. Plan.
3. Block.
4. Make sure the camera is in focus and white balanced.
5. Make sure the audio is good--have a pair of headphones.
6. Have fun, make mistakes, realize this isn't the masterpiece you'll be making. yet!
heath
Cole McDonald March 1st, 2006 07:14 AM
Here's my checklist that I've developped over the past year (previously posted on another board):
...I slated other people to do the other jobs...murphy's law struck and life got in the way. I've ended up doing most of the jobs on the set. My advice for this is to schedule more time than you need, setup early with stand-ins so the actors don't get annoyed with you for making them stand around (hey, I did slate others to do the lighting sound etc.). Keep a very critical eye all the time. Have a checklist taped to the tripod with your workflow on it. Use it every time before you say action, no exceptions!
Readthrough
Block
Props
Lights (I recommend flourescents for the lack of heat)
Framing
Focus
Polarizer (yes, even indoors I use them)
Check for glare from the lights
Check frame for extraneous crap (mic stands, exposed logos, people's feet)
Exposure
Focus
Sound
Focus
Rolling
Quiet Please!
Slate
Background!
Action!
... (listen for sounds other than what the actors are supposed to be making)
Cut!
Lather
Rinse
Repeat
Emre Safak March 1st, 2006 08:24 AM
Listen to Cole! If I had followed his checklist I would not have had to do rig removal in post.
Cole McDonald March 1st, 2006 08:50 AM
Listen to Cole!
I don't know that I've ever had someone make such a bold positive statement about me before ;) This stuff is all developed from making mistakes on set. The movie I'm making now is specifically a feature length learning piece. Play with it, screw up...you can't help but learn from doing!
Paul Jefferies March 1st, 2006 01:29 PM
Get some crew on your shoot! At least one or two other people. Really, there's loads of people who would be only too happy to lift boxes, get coffee and drive trucks for no pay just so they can say "I was on a film shoot last weekend". Big companies should feel guilty about taking on unpaid crew but when you're just starting out its the only way to get things done. And, you can learn from their mistakes as well as your own. Just make sure you thank them and buy them some food/beer and send them a DVD when it's finished.
Aviv Hallale April 10th, 2006 01:55 PM
One recommendation: Previz EVERYTHING. Make sure that every shot has been storyboarded, make use of a floor plan and a shotlist. That way you can go into your shoot knowing exactly what you want done and how, this will save you time, energy and project an air of experience towards your talents.
Heath McKnight April 10th, 2006 02:09 PM
Visit the location with your DP and even the cast to block stuff out and be prepared.
A former fire fighter once said, "If you fail to plan, you plan to fail." It's that simple.
heath
Marco Leavitt April 10th, 2006 02:36 PM
Best way to find a crew is to volunteer on other people's shoots. A lot of times they'll return the favor and you will learn a lot quicker by watching what they do.
