who's got 24 p.frames out of 60i, without blended fields every 2/3 frames ?
DVFilm don't convince me entirely, because of the blended fields every 2 or 3 frames.
vegas is the same story. With MB is still jerky, even with the shutter at 1/60. Everybody talks about nattress, but i'm in windows enviroment. ------------ A long time has passed since some said it was impossible to get smooth 24-Look out of 60i. Any luck yet?, or we are still stuck with the jerkyness? |
1- You NEED to watch the footage play back on a CRT-based TV or broadcast monitor, if that is your target format. Things look very different on TV compared to a computer monitor.
2- If you're playing things back on a computer monitor you may see blended fields from the 3:2 pulldown. You can avoid this by using a 24p project... but a computer monitor is still totally off from what you'd see on a TV. 3- You may find 24p jerky because it is only 24 frames per second. Higher frames per second would give you smoother motion... you can try 60i --> 30p. 60i would give you smoother motion, although subjectively you may like the look of 30p better. Look at adaptive deinterlacers like Mike Crash's one for Vegas (free/donation). Set it up in a progressive project, not upper/lower field first. Turn off Vegas deinterlacing. |
I'm working with some cartoons that are actually at 12fps, and i'm planning to duplicate that, to make it 24fps.
So i need backgrounds from real life, at 24 progressive, but i want to prevent those blended fields that happens sometimes with dvfilm and vegas. Because that kills the scense of the drawings, and it doesn't look right. I'm looking for a 24p conversion like magic bullet, but a little bit smoother, and less jerky. PLAIN stills, no blendings is more what i'm looking for, MB does it, but it moves a little bit strange. Any tip will be appreciated, thanks in advance. I'm using a samsung DVcam with shutter at (1/60). |
Of course I suppose there might still be a difference between TV which is broadcast over cable and what you see on your computer monitor however. |
There's really no way to do it simply by remapping fields - the math just doesn't work. The only way to get smooth 24p out of 60i (60p) is to use a program like Twixtor to time remap / reconstruct the whole thing (very slow - which is why field blending is usually good enough).
Twixtor works by taking two distinct keyframes (frame or field) and generating the appropriate frames between them based on the motion traveled of each individual pixel. Rather than trying to do funky field shifting, it reconstructs every frame. You can do everything from simple 60i -> 24p to 99p to 76i to amazing Hollywood slowmos. If you've ever seen the greenscreen footage of the Matrix slow mo revolving sequences, you've got a good example of how Twixtor/time reconstruction works. |
I tried twixtor in the past, but i couldn't get my eyes tuned enough, to see what was really going on. All this idea of going back with twixtor, makes me want to shoot myself on face. On the balls too BTW. |
Use Cinema Tools if you're on a Mac to do a reverse telecine on the footage, basically you'll end up with 23.976 interlaced footage, then apply an adaptive deinterlacer. Same method with 30p or frame mode footage minus the deinterlacing of course. On a PC you can use AE to get the same resulsts using their pulldown remover. It's kind of a testing process. I've gotten some pretty good results.
Are you saying you don't like the motion blur? In that case, there should be a way to shoot with a very high shutter in 60i and discard most of the frames.
Or the interlaced jaggies / venetian blind effect that happens from 3:2 pulldown? (Which won't happen in a 24p project, which is what you should work in.) |
Robert,
The reverse telecine to 23.976, then run it through DVFilm Maker with only the "deinterlace when motion is present" and no editing options, and you'll get the full frames you are looking for. Warning, however, you can't really edit the footage, because the fields selected assumes a certain 2:3 pulldown order on playback. If you edit and end up off by a single frame, it'll being showing short frames for a long period of time and long frames for a short period of time, and it will be very stuttery. So, that is sort of a last step if you edit in 60i, then convert to 24p last. Really, the blended frames bothered me at first, but you can't tell on playback. And a side effect of the blend is that it prevents the motion from getting too stuttery. So, it looks weird while editing, but it's fine on a TV. Josh |
If you just use a DVD playback program like WinDVD or PowerDVD instead of Media Player, you can play back the 30 fps (24p spread among 30 frames with a 3:2 puldown) and see the proper 24 progressive frames played back on your computer monitor.
Just for my info: why does media player not do this and PowerDVD does? Is there an option that can be set in the preferences?
