Dolly out and Zoom out
Is there a technical term for a shot where you dolly out and simultaneously zoom out? Also, can you point me to any example clips of where this is used?
I'll be shooting a movie where there is a fashion show scene and was thinking of possibly using something like this for a runway walk. Any thoughts on how it would fit into a scene like that? Thanks, Garrett |
Hey Garrett,
Man I'm blanking out , can't remember the tech name for it but I know there's a pretty long thread about it from not too long ago. Hitchcock used to use this technique in a number of his films. I wish I could remember the name. |
http://www.dvinfo.net/forum/document...e-closing.html As for a name, how about "reverse dolly zoom?" |
Thanks Colin, yeah that's what I was thinking about. Man between the cold weather and the age I need to look at my drivers license every morning to make sure of my own name.
What were we talking about? O|O \--/ |
Don and Colin, thanks.
Colin, you're correct, it's not a dolly zoom in the typical sense (zoom in/dolly out or zoom out/dolly in). I can't remember if I've ever seen this. In my mind it could give a really interesting effect but maybe it would be too weird. OK. Something for me to try. Who knows, maybe if I'm the first I'd get to name it...HEHE -Garrett |
People dolly and zoom out at the same time a lot. It helps to hide the zoom effect but is necessary when you have to cover a wide area and you don't have enough space. Zooming out also changes perspective.
Dollying out, zooming in and pulling focus? That has been done before too. But it's such a tacky shot which calls attention to itself. My opinion, of course. |
Can you give any examples? I don't believe it is done a lot. Dollying and Zooming give much different results even though many people think they do the same thing. I've been watching for this and haven't been able to identify a shot using it.
As I said, when I get some time I'll do some test shots as I may want to use it for a scene if it gives the effect I'm thinking it might. -Garrett |
Nope Travis, I've done dolly zooms before. That's where the zoom and dolly are moving in different directions, i.e. zoom in - dolly out or dolly in - zoom out. The key for that shot be effective is that the dolly move and zoom rate have to be coordinated to keep the main subject at approximately the same relative size in the frame.
I'm thinking of dollying out (or pulling back) while zooming out. Zooming out decreases the size of the objects in the frame while filling the frame with more objects. Zooming keeps relative angles and differences in focal lengths between object constant. Dolly out will change the relative angles and focal lengths to each object within the frame. If I'm imagining it correctly, it should give somewhat of a warp effect like being pulled up backwards out of a whole while waking up and coming out of tunnel vision. I may be imagining in CGI though ;-) Garrett |
There is a dolly zoom where the girl stays the same size in the frame and the background seems to close in on her - ie the the camera dollies away from her while the lens zooms in on her. Is this not the reverse of the 'Vertigo' example nornally used and what you are meaning, Garrett? "Reverse dolly zoom" won't do for a name - it sounds like Vertigo run backwards. How about "INVERSE dolly zoom"? |
To answer the first question, the official name of this move is still 'dolly zoom'. It's just that the version famous is the Hitchcock or vertigo zoom. Theoretically, any move with both dolly and zoom is called a dolly zoom. Having said that, if you can produce a cool new effect, they'll probably name it after you! |
Thanks, Garrett |
Garrett, I see now that's clear from your first post. Sorry to confuse the issue!
I've seen it called a "Zolly" - not the kind of shot you'd want to try to pull off on a live event.
I'm looking for a way to show the frantic pace of a fashion show without using the usual whip zoom/pans and rapid cuts. I was was thinking that this might be a good opening to the scene. |
Do you have dolly track you could practice this on to see if it is the effect you would like or do you have to rent track?
If you do a test shot, post the results on vimeo or something. I'd like to see how it looks. |
Re: Dolly out and Zoom out
Actually Hitchcock would zoom in / dolly out or vice versa, not zoom out / dolly out.
If you dolly out and zoom out at the same time, what you'll end up with is a zoom out that is twice as fast.
Denny: I have done the dolly/zoom effect on tripod dolly wheels and always wished we had spent the time to lay track...
And yes, the classical usage is dolly opposite to the zoom... |
A dolly out plus zoom out will not give the same look as a zoom twice as fast or a dolly twice as fast. Dolly moves and zooms have a different effect on the perspective of the objects in frame. That is why you sometimes move the camera closer and use a shorter focal length lens versus keeping the camera in the same location and just zooming in.
-Garrett |
You are correct. Zoom is not the correct word. What I meant was that if you dolly out and zoom out simultaneously, you'll end up with subject image size that gets smaller, with an increase in apparent perspective. But have you actually tried it? The effect looks like a mistake.
After all this time of thinking about it I haven't had a chance to try it yet. I'm not sure it will look like a mistake but it will be an effect. I was wondering what type of feel that look would invoke. I'll have to try it but I want to have the subject in a fairly confined space with some interesting set dressing on the sides and behind.
Warren, do you have an example of this? -Garrett |
| All times are GMT -6. The time now is 01:07 PM. |
