-   Techniques for Independent Production (https://www.dvinfo.net/forum/techniques-independent-production/)
-   -   true 16:9 (https://www.dvinfo.net/forum/techniques-independent-production/40964-true-16-9-a.html)
Matt Lean March 11th, 2005 07:29 PM
true 16:9
Hey guys, I have a gl1 with an anamorphic adapter (True 16:9). Would I lose quality if I cropped it for 2.35:1?
Boyd Ostroff March 11th, 2005 08:35 PM
You don't "lose quality," but you do lose the pixels which will have black bars on them. Unfortunately this is the only way to do 2.35:1, unless you want to get into upconverting to HD or using a projector with an anamorphic lens.
Aaron Shaw March 11th, 2005 11:03 PM
Using a projector with an anamorphic lens won't work. It would stretch your 16:9 image out too wide.
These are your only options:
1) Crop in post. You will loose roughly 25% of your resolution (assuming you shoot 16:9).
2) Shoot with an anamorphic projector lens instead of a 16:9 lens. This will create a 2.66 image - noticably wider than 2.35 but an interesting option.
3) Make your own anamorphic lens
Matt Lean March 12th, 2005 12:42 AM
I will lose 25% of resolution??? By my anamorphic adapter will give me true 16:9. Using a 2:35:1 will make the resolution 25% worse??
Mathieu Ghekiere March 12th, 2005 08:22 AM
Normal 16/9 is (I think) 1.85 aspect ratio.
You want 2.35 aspect ratio, that's I think almost the double or something. So If you would want it at full resolution, you would have to have OR a 2.35 adaptor (I don't know if that exists for DV cams) or crop it in post, so you have 2 times 1.85 = 2.35.
But yes then you'll loose some resolution, but... resolution isn't that important unless you plan to blow it up.
Good luck.
Rob Lohman March 12th, 2005 08:25 AM
Actually, 16/9 is 1.78 (divide 16.... by 9!). But it is pretty close to 1.85:1 indeed.
Boyd Ostroff March 12th, 2005 10:15 AM
Aaron, you don't understand what I'm suggesting - sorry, I didn't explain. If you set the camera for anamorphic widescreen mode ("electronic 16:9") and you also put the anamorphic lens on it, then you'll end up with roughtly 2.35:1 anamorphic on your tape.
Now when you project this, set the projector for anamorphic 16:9 mode and use an anamorphic lens on it. That will unsqueeze this back to 2.35:1. This is one company that makes a lens you could use http://www.panamorph.com
Aaron Shaw March 12th, 2005 10:45 AM
Ah ok! Thanks for clarifying Boyd!
Matt: By cropping a true 16:9 image to 2.35 you loose about 25% of the image resolution (it's covered by black bars).
Mathieu Ghekiere March 12th, 2005 10:52 AM
<<<-- Originally posted by Rob Lohman : Actually, 16/9 is 1.78 (divide 16.... by 9!). But it is pretty close to 1.85:1 indeed. -->>>
Thanks for clearing that up, I was still doubting between the two :-)
