-   Techniques for Independent Production (https://www.dvinfo.net/forum/techniques-independent-production/)
-   -   From 1/3" to 1/2" 3ccd camcorder: dof difference? (https://www.dvinfo.net/forum/techniques-independent-production/27534-1-3-1-2-3ccd-camcorder-dof-difference.html)
Riccardo De Cal June 14th, 2004 05:25 AM
Hello everybody,
another dof question.
How much shallower dof gives a 1/2" camcorder respect a 1/3" one? Say, a Panasonic DVC200 vs a Canon Xl1s..
I was thinking two ways to refresh my camera setup: buy a new DVC200 or a P+S technik Mini35 adapter for the Xl1s.
What do you think is the best deal?
Thanks for any thoughts, inputs, etc.
Ric
Rob Lohman June 14th, 2004 05:48 AM
I understood from Charles Papert that even with a 2/3" CCD
(which is even larger) the DOF will not change enough. So I
doubt 1/2" will get you where you want to go.
But I leave it to other people who are a bit more in the know
to either confirm or deny this claim I just made.
Imran Zaidi June 14th, 2004 12:14 PM
Even with the larger chip size, there is no way the DOF would be able to compete with the DOF control of a Mini35. If it's DOF you're after and have a good existing camera and the money for either a bigger chip camera or a Mini35, I sure as heck would go for the Mini35.
After all, look at the fine work Charles did for AmEx on the Seinfeld spots with an XL1 and a Mini35.
Jeff Donald June 14th, 2004 01:21 PM
These chips are not as big as you might believe. A 1/3 inch chip is about 4.8mm X 3.6mm and a 1/2 inch chip is about 6.4mm X4.8mm. The diagonals are 6mm and 8mm respectively. The diagonal for 35mm film is about 44mm. That is a huge difference. The small chips change in DOF is probably on the order of 10% or so.
Barry Green June 14th, 2004 02:44 PM
At equivalent distance to subject, a 1/2" camera needs a 30% longer lens to deliver the same field of view, when compared to a 1/3" camera.
So let's assume you're talking about a PD170 at its maximum telephoto, 72mm. At 10 feet from the subject, and f/2.8, the PD170 would have a DOF of about 4.25". A 1/2" camera would need about a 94mm lens for the same field of view, and would thus deliver a DOF of about 3.75".
Let's assume the same settings, but at 30mm on the PD170 (and, correspondingly, 39mm on the 1/2" camera). At 10 feet, the PD170 would have a DOF of 25.25". The 1/2" camera would be at 21.75".
At the extreme end, let's take a fairly wide-angle shot of something 50 feet away, at f/2. The PD170 would be at maybe 20mm, the 1/2" camera at about 26mm. The PD170 would have a DOF of about 280 feet. The 1/2" camera has a DOF of about 150'.
So, there's a difference, but not a BIG difference. Certainly nowhere near as much as you'd get with a 2/3" camera, and nowhere in the ballpark as compared to a 35mm movie camera.
