From HDV to the Big Screen.
Okay, like many of my fellow DV Info'ers I am planning to take my footage from Mini DV to the Big Screen. Can any of you pro's out there give me some insight as well as a workflow on the Telecine process from start to finish(please include any insight you may have from previous experience). I've searched but can't find a thread on this. If there is one can you, oh mighty wrangler, direct me to it. Thx.
Hi,
Is it one time deal or you got distribution deal? 7 years ago I just took my sony vx 1000 and hooked directly to projector in movie theatre. You can also play from DVD it was one screening only - zero problems Mike |
It would be for a distribution deal. Being miniDV It wouldn't go through Telecine. But, what is the process?
Lee,
What are you talking about, a blow up to 35mm? You really need to get in contact directly with the house that will do the blow up? You might want to talk to these people for example: www.dvfilm.com. They're in your area (or at least in your state). I've seen the results of their work from miniDV and it's pretty good. However you might want to concentrate on getting a distribution deal first. Once you've secured that then worry about the blow up. In the mean time just prepare the best 24p master you can, with a good color correction pass and full sound mix. One thing I will say is really you needed to start asking questions like this before you started shooting. The whole workflow is pretty involved and complex. You could do worse than go back and start reading many of the posts on Mike Curtis' HD for Indies Blog if only to get a sense of what you do and don't already know. |
Thanks Dylan... I haven't shot my footage yet, I am gathering info and trying to determine the best workflow. The plan is to take the footage and enter it into the indie festival circuit. I was trying to gain wisdom without having to go through the mistakes myself... Trying to avoid any possible telecine horror stories.
Then that's great, this is exactly the right time to start asking questions. The trick is to sort out your post production route as soon as possible. What you're talking about is not a telecine, that's transferring file to video, not vice versa! That alone suggests you're quite new to this and so I suggest hiring someone who can talk you through the whole process, which Mike Curtis from HD for Indies used to do, I don't know if he's given consultancy up now he's moved to LA with his Red One.
This is something I've thrown together from what I know, but it's by no means an exhaustive list of things you have to know.
Anyway, the most important piece of advice is get your post workflow sorted out as soon as possible. It's not really a case of getting good advice, it's a case of knowing who is going to be responsible at what stage and what they are going to receive and then deliver, right down the the format/codec of the video and audio itself. |
| All times are GMT -6. The time now is 10:39 PM. |
