Dvd insert printing, costing
Hi,
Until now I've used Costco photopaper and an HP inkjet to print my Dvd inserts for amateur theater productions. Most of the front is just black text, the production company, the show, when/where, and maybe a stylized color image of the marque. On the back is a clip from the closing showing the cast, in full color, 1/3 the height of the back cover, wide screen (hd) 16:9 format. One group has asked that I use their promotion material on the front cover. Given that it is full bleed color I don't want to imagine what my costs will be (I used to put a lot of photos on the inserts, but not a single full bleed background, and was seeing $1 to $2 in ink costs per dvd). Its too late to ask them to include in their print run dvd inserts, plus this doesn't really benefit any of my other customers. Have any of you used a color laser for full bleed inserts? My production runs are 15 to 40, averaging 25. (by full bleed I meaning that there is edge to edge print, no unprinted areas) thanks jim cowan |
Re: Dvd insert printing, costing
Color laser is kind of unimpressive compared to inkjet on semi-gloss. I also certainly would
not have one of the chain office whatever or copy+shipping shops do it unless I knew the client was blind. If you are doing a run of 45 or so you can probably find an online print shop that will do full bleed to a 8.5x11 flyer for between $1.10 and $1.45 per page shipped. I probably can't name names but if you spend an hour looking around you can probably find a decent vendor. Only use vendors that tell you what CMYK colorspace they work in. The 4 color offset takes more work to design, you have to figure out CMYK proofing, it takes weeks to print and doesn't look quite as good as a 6+ color inkjet. It is cheaper though. |
Color inkjet with photo paper quality will surpass color laser IMO.
I have been printing full color on Costco Kirkland photo paper with Epson stylus photo printer with Continuous Ink System CISS. The cost for printing full page color would be minimal. I have been stop buying expensive cartridges and been using CISS for a couple of years now. You can find them on ebay. You can PM me for the vendor I bought from. |
Have you looked into a DVD printing service like Kunaki.com?
Anyway, I'd also suggest you take a look at Kunaki.com. Very affordable with no minimums. Keep in mind it's 100% automated, so be sure to proof everything because there will be no human eyes double-checking your work. |
One other thing is cutting the paper. I found a great paper cutter from Guillo Max that allows me to cut 50 to 100 at a time. This is total in-house stuff and allows you to make sale ready output from your closed system. I really like the design flexibility and turnaround. |
I tried Pigment and Dye on CIS. Pigment last forever but the output is dull and not as accurate. I like Dye better than Pigment.
