film info?
i found my dads slr camera,which takes 35mm film,i really want to learn about all the diffrent films thier are out their.can someone hlp.thank you
Wow, that's a really broad question. There's a lot of consumer and professional film types out there, both in b&w and color. Your best bet would probably join a photography forum and let people know what you want and what film would work best.
i want to know the profesional film.
Usually the slower the film, the sharper the neg or positive. Some films have for latitude meaning a stop over or under is barely noticeable. Figure out first what type of shooting you want to do.
i just got the kodak portra,vivid color 160vc.and a fujicolor peo 400.are thiese any good?
As a professional, I mainly use Fujichrome Velvia 50 & Velvia 100 ISO colour positive transparency film (I never use colour negative print film).
If digital files are needed, then the slides are then turned into very high quality digital Tiff files of 50Mb, 100MB, or 200MB using a top-grade desktop 35mm scanner or Drum scanner (for use in colour magazines, calendars, adverts, and books). |
whats the diffrence between negative and pasitive
"Velvia 50 & Velvia 100 ISO" Right on!
Yes. There are a couple of Velvia 100 versions (maybe even 3), and I beleve Fuji brought the 50 back.
