-   Still Crazy (https://www.dvinfo.net/forum/still-crazy/)
-   -   Camera recommendation? (https://www.dvinfo.net/forum/still-crazy/23393-camera-recommendation.html)
Heath McKnight March 23rd, 2004 10:35 AM
I'm starting to sell action figures, statues, other toys, comics and such on eBay. I was told a zoom lens is good, but a flash isn't, but lights are.
Can someone recommend a great, affordable digital camera, what kind and how many lights and anything else I may need?
I'm on a tight budget, though...
THANKS!
heath
Rob Belics March 23rd, 2004 11:54 AM
All you need is a camera unless you're shooting in the dark. Set up a table by the window and use natural light. You don't need no stinking zoom. But most digitals come with one.
Will Downing March 23rd, 2004 12:25 PM
Heath,
I'll probably get flamed, but I would recommend a good used Sony Mavica MVC-FD 92 for what you're wanting to do. It shoots on either floppy disk, or Memory stick w/ 1.6 Megapixels. We have a couple around our shop, and for quicky projects for powerpoint or the web it works well. It also has a very decent macro setting and a decent zoom. Sony sells a the MVC-FD200 on their website for around 299.00 US, but I haven't used them at all. We also have a couple of the CD-1000's, CD-500's and they work well for what we use them for. The added benefit of the CD series is the flash attachment. (The FD200 may also have this, but again no practical experience)
I am suggesting these because of the macro features, which for action figures would work out well. If you have the extra scratch, look at the Canon EOS Rebel w/ a macro lens, or the Nikon D100. I've used the Canon, and have a friend w/ the Nikon, and both DSLR's work well. The downside is cost, both for a body and lenses.
Lighting: If you have lights for your DV camera, you're in business. They work just as well for digital camera work. I would bounce the light off of foamcore, or get a diffuser though, just to keep the harsh shadows to a minimum and to flood the scene. If you don't have lights, then Rob is correct. Use a north window light setup w/ a reflector and go to town.
Good luck, and if you have the opportunity and a local camera store, take a figurine in and play with the various display models. This will give you an even better idea of what works and doesn't for you.
Will
Jeff Donald March 23rd, 2004 12:47 PM
No ones going to flame you Will, that's not the way things are around here. However, I feel the Sony is too limiting in it's capabilities. Heath, what kind of budget do you have? Some of the less expensive Canon, Nikon, and Olympus cameras offer enhanced capabilities, good quality and more flexibility.
Will Downing March 23rd, 2004 01:08 PM
Jeff,
I appreciate the courtesy here, I just won't post other places as a rule due to the rude culture that is so pervasive. I agree with you on the limits of the Sony Mavicas, but without knowing what Heath is trying to do, I figured that would spur conversation. I am also impressed with the Nikon Coolpics line, but, as you asked, without knowing a budget or usage I took a flyer and threw out a couple of models we've used with some success. Have you any experience with the Olympus digitals. I keep getting questions from some of our staff about them, but I haven't any personal experience. The way things change so quickly keeping up is darned near impossible.
Later,
Will
Heath McKnight March 23rd, 2004 02:56 PM
Thanks, everyone!
Jeff, my budget is limited to around $200 for the camera and maybe $100 for lights. I just want to shoot action figures in their boxes/cases that look great and show any flaws on the packaging (or on loose figures, out of the cases).
I don't want to post a direct link, but for an example, just go to ebay.com and look up Spider-Man figures and see what other people do.
THANKS!!!!!
heath
Jeff Donald March 23rd, 2004 03:47 PM
You're not going to need that for lights. since your subject is not moving, get yourself some small hot-lights and keep it simple. Bounce the lights of the white walls or some foam core. Take a look at the lower end models I mentioned and see what fits your budget, hands, style of shooting etc.
Heath McKnight March 23rd, 2004 04:03 PM
Since I'm so new, can you recommend some "hot lights" brands, please, Jeff?
heath
Will Downing March 23rd, 2004 04:22 PM
Heath,
You can go a couple of routes for the lights. Perhaps the easiest is dropping by your local home improvement store and looking over the selection of halogen lights. You can get a wide variety of wattages and sizes. I would second Jeff's comment on bouncing these off of a wall, ceiling or bounce card. Be aware they are called "hot" lights for a reason, so be sure you can cool your work area appropriately.
There are several threads in the lighting forum about JTL and Smith/Victor lights, and each will work well shooting either digital stills or DV. Our local photo store sells several "Digital Light Kits" which are S/V lights w/ 50 to 300 watt bulbs. (May be off on wattage, but I'm in the ballpark)
If you're somewhat handy with tools, there was an intriguing article on lighting in DV Magazine by Walter Graff, and a thread somewhere around here on how to make his fluorescent lights using common components found at the hardware store. He's calling it the "Grafflight" and I think we'll probably make a couple for use in our shop. (Sorry I can't remember the link, but a search should come up with it) These would be much cooler, and your digital camera's white balance shouldn't be affected.
I'll defer to Jeff on other brands, since we use our Lowell kit whenever we need hotlights. But for starters a good shoplight might just be the ticket. Sorry if this seems to be steering you toward "cheap" solutions, but working for state government has led toward trying creative solutions in lieu of money for "stuff"
Will
Jeff Donald March 23rd, 2004 04:30 PM
You can use almost anything, including GE 100 watt household lamps. Just use AWB or do a manual WB. Get some clip lamps or small reflectors, bounce cards and go to it. If you have the space, you can do it outside even (much cooler). I wouldn't invest big bucks in lights right off. Get a decent camera and get better lights as your venture starts making money. Then you can get something that'll do dual duty for still and video.
Heath McKnight March 23rd, 2004 04:34 PM
Jeff and Will,
You both rock, as do everyone else!
I've been doing a little research and came across the EZcube. Any thoughts? Some people like it for the kind of stuff I want to do.
I'm also researching how toy magazines take pictures of figures; looks like it's a much higher budgeted version of what you all described.
THANKS AGAIN!
heath
Will Downing March 23rd, 2004 04:35 PM
Heath,
I cherry picked this from a post Chris Hurd had in the lights forum that's in the dvinfo articles file. For $30.00, we will probably try to build one of these as well.
http://www.dvinfo.net/articles/lighting/clantern1.php
I forget how much information there is on DV Info.
Will
Heath McKnight March 23rd, 2004 04:49 PM
I just saw how much those EZCubes cost! (And their two lights cost $150!) I'd be out around $300 BEFORE I buy the camera...
It is, however, quite nice and convenient, but I can probably duplicate something for a fraction of the cost.
heath
Dylan Couper March 23rd, 2004 06:40 PM
Heath
For $200 I would look for a used Canon A series cameras A60, A70 might be in that price range used. My vote might be for the Canon A80. Small-ish, well featured, flip out LCD for odd angles when taking pics of your stuff. I think if you want to shoot action figures for Ebay, you should forget about the on camera flash and just buy two lights to use off camera.
I have a little setup for Ebay stuff which consists of white photo background paper and two long arm/hinged desk style lamps with 60w daylight style incandescant bulbs. The lamps cost me $11each, the bulbs were $1 each, the photo paper was $36 for a huge roll. All prices are in $Cdn so take 25% off. So a total of about $45us. I can take a picture of the setup and send it to you if you want.
The desk lamps are the same as the company Pixar uses in it's 3D title before a movie, except they are clamp to the desk.
Heath McKnight March 23rd, 2004 07:10 PM
Yeah, send me a pic. heath@mpsdigital.com is my email.
heath
Rob Belics March 23rd, 2004 10:53 PM
What is the deal with this? I went to ebay and all I saw were these things sitting on a little table but it sounds like it's turning into a big Hollywood production!
Am I missing something?
Adrian Douglas March 23rd, 2004 11:15 PM
Heath, instead of zoom for shooting action figures and the like you should be looking for a camera with good macro function.
You can build your own EZCube type deal from white poly pipe and oven proof baking paper. Does the same job but costs about $10.
Tommy Haupfear March 24th, 2004 12:49 AM
Agreed, I sell a good bit on eBay and when I need a close up I use my small 3CCD camcorder.
Here is a macro shot I took with a compact 3CCD Panasonic.
http://img.villagephotos.com/p/2003-...Picture360.jpg
My vote for a used cam would be a Canon G2 (black of course) or a brand new Pentax Optio 33LF . The Optio has 3.2 megapixels, a 3x optical zoom, flip-out LCD, and a decent macro function all for $219 at B&H.
Here is a pic
http://im2.onecall.com/Image_Product...o33lflarge.jpg
Jeff Donald March 24th, 2004 12:59 AM
Almost all digital still cameras have great macro range. Most of the the Nikon's focus down to 8/10's of an inch (about 2 cm). Even the less expensive ones will focus down to 4 or 5 inches.
Heath McKnight March 24th, 2004 08:50 AM
I just want to take good photos of a LOT of figures!
heath
Chris Hurd March 24th, 2004 09:20 AM
Heath
The only digicam experience I have is with the Canon line. I'll second the recommendation for their PowerShot "A" series. You don't need the high megapixels since these are photos going to Ebay... even a 2mp camera will suffice. The Canon PowerShot A60 or A70/A75 (2mp and 3mp/3mp) will do the job quite nicely, although the 4mp PowerShot A80 is the king of the A-series. They have built-in macro shooting modes, or you can add a close-up lens attachment. They are feature-packed cameras at a low price. Get a set of rechargeable batts (they each take four AA's), and use the included Remote Capture software to take pictures directly from your computer keyboard via USB and transfer straight to your hard drive. This gets you out of the requirement for a high-capacity memory card... remote capture in a studio or office setting has these distinct advantages. $50 or less for a couple of photoflood bulbs and clip-lamps and you're all set. Hope this helps,
Heath McKnight March 24th, 2004 10:12 AM
Chris,
Yes, it helps tremendously!
heath
Heath McKnight March 24th, 2004 02:49 PM
I bought the Canon A60 with an Impact Tripod. Hope those sticks don't suck!
heath
Dylan Couper March 29th, 2004 02:02 PM
<<<-- Originally posted by Heath McKnight : Yeah, send me a pic. heath@mpsdigital.com is my email.
heath -->>>
Heath
Just sent it to you.
Heath McKnight March 29th, 2004 02:24 PM
Got it, thanks! Nice camera and nice video camera you were photographing!
heath
