-   Stabilizers (Steadicam etc.) (https://www.dvinfo.net/forum/stabilizers-steadicam-etc/)
-   -   Do you NEED a smooth shooter with the Glidecam? (https://www.dvinfo.net/forum/stabilizers-steadicam-etc/99275-do-you-need-smooth-shooter-glidecam.html)
James Carver July 19th, 2007 07:03 AM
can you buy the glidecam 4000 and just the body support and still get the same smooth shots as using the smooth shooter thing?
is there that big of a difference?
Mikko Wilson July 19th, 2007 07:51 AM
Nope, the Body-Bod doesn't provide any stabilisation. It's just a mobile "dock"
- Mikko
Terry Thompson July 20th, 2007 01:03 AM
It's good for lock off shots though...you can also pan and tilt but just don't walk.
Tery
Indicam
James Carver July 20th, 2007 01:30 PM
yea i can use my spiderbrace for that or tripod. i was thinking the glidecam was about $500 but after adding the smooth shooter it's out of my price range. i'll have to find a DIY way of getting smooth shots...
Terry Thompson July 20th, 2007 03:31 PM
James,
What camera are you using? How long will your shots be?
The reason I ask is I have used our Indicam PILOT sled for a great deal of shots that don't take very long to shoot. They are usually 30 seconds or less and they still look good. We switch over to our body mounted system when we shoot longer scenes or are shooting for an extended period of time.
An example of some of our handheld shots is found on our Flash Video page:
http://www.indicam.com/media/Flash/flvplayer.html (Click on the last video.)
A decent DIY option is when you have the camera mounted on a tripod, collapse the tripod and shorten it just a bit and then hold it near it's center of gravity. This can yield some usable shots although they won't look like a true stabilizer can produce. Hopefully your tripod isn't too heavy.
Good luck.
Tery
Indicam
James Carver July 21st, 2007 07:39 PM
yea the shots would be longer than 30 seconds as i'm doing narrative short films. i'm using an HVX which is not so lightweight. i may try the tripod suggestion you mentioned since i have a cheap lightweight one. i can't imagine using my Bogen tripod. that thing is heavy.
