-   Stabilizers (Steadicam etc.) (https://www.dvinfo.net/forum/stabilizers-steadicam-etc/)
-   -   Smooth shooter (https://www.dvinfo.net/forum/stabilizers-steadicam-etc/56105-smooth-shooter.html)
John Benton December 15th, 2005 11:18 AM
Smooth shooter
the low end from Glidecam
looks like it is something between a one & two arm rig
http://www.glidecam.com/product-smooth-shooter.php
What do people think of this?
Has anyone used it?
I am looking for something that is not just a support for a stabilizer,
((Like the DV sportster is,
or even the Navigator:
http://www.varizoom.com/products/sta...navigator.html
but a little more of a walking rig,, which I think you need two arms for?
NOTE : It says the Smooth Shooter has replaced the Glidecam V8 (which looks a bit more robust - I might be abble to get my hands on one of the v8's still though it's a bit more expensive
J
Charles Papert December 15th, 2005 02:20 PM
John:
The Smooth Shooter does represent an upgrade in technology and performance over the older GC arms, including the dual-section ones. You do not need two sections to achieve smooth walking shots, although it is helpful. A single-section arm will restrict the amount of boom range and most importantly maximum vertical height, so if you are on the shorter side you might not be able to get the lens up to your subject's eyeline.
John Benton December 15th, 2005 07:42 PM
Thanks Charles,
I think I am going to take the plunge and just want as much info as possible...
I saw this video
http://www.pingpongcams.com/glidecam...hooter/videos/
and While I think it was Not Shot with the Smooth shooter (the reflection in the car looks like a larger model)
It was very reassuring
John
