PD150 on a Glidecam 2000 PRO
Possibly more suited to the Support Your Cam forums, but those guys own scarily big rigs, whereas I know everyone here at least has a PD150.
My rig is generally a PD150 w/ the Sony 0.7x and a 960 (think thats the right model#) 8hour battery on the back. I haven't had time to try recently, but I've had an impossible time trying to balance the thing, Ive read the manual multiple times, but still no luck. Does anyone else have a GC2K for their 150/170 , if so what combo of weights are you using at least? That'll hopefully give me a kick in the right direction.. drop time seems to be ok, but I just can't keep the thing steady... argh! (Never knew how heavy the whole thing would be too, I need to work out more!) |
I flew my VX2100 this last weekend. I have 4 big washers on each side and the mast is about half down. You weigh a little more, but I would guess the same washers with a slightly shorter height.
Cheers for that, I'll start off with that as a base and see if I can get more joy out of it :) Thanks
Hi James
I use a Glidecam 2000 with my PD-150. One thing that is different is that I use a Canon WD-58 WA lens, which is a little lighter than the Sony model. I also use a quick release plate, which adds weight as well. I have the mast fully extended and I use 5 of the big weights. Do you use your thumb and 1st finger on your left hand to help guide and steer the Glidecam? |
I spent some of today balancing 5 GC2000’s with nearly the exact same set up (PD170s)
You need 4 disks on each side and as has been said, the post is about half way. Good luck, -Rick. |
James:
If the rig sits level when you aren't touching it, and the drop time is OK, it sounds like you either have a mechanical problem or an operating issue. If you have any way to post a short video of yourself doing a simple move with the rig, we would be able to critique your form and see if there is anything obvious that needs addressing. |
Thanks for the replies, I'll see if I can get a chance over the weekend to try it again, and if there's still no luck I'll shoot a quick video with my other camera. Much happier behind the lens mind! :)
Cheers |
| All times are GMT -6. The time now is 11:22 AM. |
