Glideam Smooth Shooter - low mode?
Hi,
haven't found if there is any low mode available for Glidecam Smooth Shooter with Glidecam 2000/4000 Pro? Thanks for any answers! |
Or for example, how low can you get with Smooth Shooter?
Hmm, good question.
Basically the question would be wether the Glidecam 2k/4k can do low mode. I too would be curious about this possibility? - Mikko. |
There is a bracket available for the old V8, I’m sure you could do it.
It's just the shape of the gimbal handle that would cause problems, as it’s at a strange angle for clearance when the sled is flipped to do low mode. |
Accessories for the Glidecam 2000 and 4000 Pro are coming soon. Among these accessories will be low-mode kit that can be used in either hand-held configuration or in conjunction with the Glidecam Smooth Shoother.
