a trustworthy stabilizer for the smaller camcorder
I have a MX1000(DV852) and I'm trying to find a realistic stabilizer for it. I think the vest stabilizers would be overkill for such a small and light camcorder. I'm looking for something that will allow me to move around without producing footage that'll give the viewer motion sickness.
Any suggestions? |
I use a Glidecam 2000 handheld stabilizer with my PDX-10, which is around a 2 lb camcorder. It should also support smaller cameras, you just use less of the weights.
However don't expect to avoid "motion sickness" without considerable practice. It takes a surprisingly long time just to setup and balance the stabilizer initially and then it will take many days of practice before you start to get the hang of it. Even with a little camera don't expect to be able to shoot more than a few minutes at a time. It's really exhausting... |
This is a good designfor very small cameras.
Charles do you think the VS1 is better than the Steadicam JR?
Not necessarily, I just like to mix up my recommendations! I think it's a nice little piece, good for small cameras and inexpensive. I think the JR allows more flexibility.
thanks
Langston,
I have a Glidecam 2000 in excellent condition for sale. E-mail me if you're interested. kriscarrillo@hotmail.com |
I have been using a VS-1 for about 2 years now to replace my old Steadicam JR(which I purchased used[and unfortunately--abused])
It works *almost* as good the JR--but some vibrations from walking and running is still noticeable(partially due to my still learning technique) unlike the silky smooth JR. (I do notice a bit of play where the offset handle meets the gimble on the VS-1 and this is where the vibrations comes from) Other than that criticism-- it is lightweight and well machined and you can make really fine adjustments for fore and aft on the stage with micrometer adjustments and an allen set screw. [The Glidecam 2000 is lacking in this area--it is much more difficult to make fine adjustments on the stage with it] You can adjust bottom heavyness on the VS-1 by raising or lowering the gimbled handle on the post and locking it down. It is really light weight and you can use it all day without fatigue. The only other real complaint I have about the VS-1 is that two of the hand tighten thumbscrews on the "quick release plate" which mounts to the camera tend to loosen fairly easily with use unless you really tighten it down. Maybe some Lock-Tite will help here. |
John:
I recommend you pass on your comments to Hollywood Lite, if you haven't already done so. Address them to Garry Tull, and if you like you can mention that I suggested you do so. |
kris check your email
does anyone have any experience with the flowpod?
do a search here under "flowpod"--it's been discussed.
what about the hollywood utra lite? any one use that? looks cooler than others in the price range... but maybe thats not how i should base EVERYTHING. input?
| All times are GMT -6. The time now is 07:40 AM. |
