How important is being a 1/2 inch behind the post?
Hello all,
I am thrilled to be part of this forum and a new Steadicam Pilot owner! That being said, here is my first question; How important is the CG being about 1/2 inch behind the post? The reason I ask is because the holes that I use on the stage is either right in the center or the next hole back is too far back. When I attach my manfrotto 577 plate the cameras CG is right in the center. If I make the CG about 1/2 inch behind with the fore and aft knob it puts it pretty much all the way back. Thanks for your help. -marco |
I also use the Manfrotto 577 with the 1/4-20 tie-down screw, and I use the center hole in the Pilot stage plate. This puts the majority of the 577 behind center, like this:
http://www.dvinfo.net/conf/attachmen...r-p9030095.jpg In the end, this all has to do with dynamic balance, which is explained in post #27 in this thread: http://www.dvinfo.net/conf/stabilize...lot-error.html I've noticed that many Sony cameras seem to be heavy on the lens side. I've flown the EX1, EX3, and the V1U (just today). In all 3 cases I had to move the 577 one hole back in order to get dynamic balance. In this position, the 577 hangs off the back of the stage plate about 1/2". |
Sorry for the delay Dave, I didn't know you replied. I selected the "Instant email notification" but did not get an email?????
I don't know which screw size I am using, but I know it fits in the front hole of the Manfrotto 577. The middle hole is biggest and the last hole I don't know. I have a tie down screw for the (big) middle hole on the Manfrotto 577 but its too big for the holes on the stage plate. Any thoughts? Here is a link to some pictures I took; Flickr: Pilot Pictures I put a white sticker to show the CG when I balanced it on a ruler Thanks for your help :) |
use the 1/4-20 screw. that's a pretty standard size and will fit the front hole of the 577 plus any camera store should carry them. The other one is a 3/8 screw which I don't belive the stage plate will handle. I could be wrong.
Don |
I use a shorter lighter shotgun with my HVX200 for Pilot run-and-gun type stuff. It's the Rode NTG-1 with SM3 shock mount and Dead-Cat furry windscreen. All 3 together weigh less than 1/2 pound, and cost around $300 shipped: Rode NTG-1 & SM3 Rode Dead Cat Wind Muff I like the NTG-1 sound, but you can judge for yourself here: DV eStore Theatre - Shotgun Shootout The NTG-2 and NTG-1 are identical except for the power source (battery vs. phantom). |
Oh... is that other screw a 3/8. Thanks I didn't know what size it was. But I couldn't understand why it would come with the Pilot if it is too big to fit in the stage plate???? |
(I don't understand why I'm not getting emailed when someone replies to my post? Any suggestions?) |
