-   Stabilizers (Steadicam etc.) (https://www.dvinfo.net/forum/stabilizers-steadicam-etc/)
-   -   FlyCam 3000 Pro (modified) test with Canon XH A1 (https://www.dvinfo.net/forum/stabilizers-steadicam-etc/129522-flycam-3000-pro-modified-test-canon-xh-a1.html)
Denys Pyevtsov September 7th, 2008 10:46 AM
Here is another more complete FlyCam 3000 Pro clip. Enjoy!
FlyCam 3000 Pro (modified) test with Canon XH A1 on Vimeo
Charles Papert September 7th, 2008 01:32 PM
Denys:
Your left hand should MUCH higher on the post, just under the gimbal. That is where the center of gravity of the rig is situated, assuming you have a standard drop time (around 2 seconds). Also, your rig is quite long--if you can stand taking on more weight, it would be better to add more at the bottom and shorten the center post.
Denys Pyevtsov September 7th, 2008 02:41 PM
Thx. IŽll give it a try.
Jordan Orberg September 9th, 2008 07:11 AM
Sweet! Thanks for posting!! What kind of on-camera monitor do you have?
-jordan
Denys Pyevtsov September 9th, 2008 02:30 PM
Thanks! Look carefully at the beginning of the clip and you will see the name of the on-camera monitor ;-)
Buba Kastorski September 10th, 2008 08:30 AM
so, what's the monitor?
I like it , who's manufacturer, how much?
Denys Pyevtsov September 10th, 2008 09:00 AM
Look here HANNS-G HANNS.mini Mini-TFT/LCD-Fernseher: TFT/LCD-Fernseher Preisvergleich - Preise bei idealo.de
Buba Kastorski September 11th, 2008 06:59 AM
Thanks Denys,
but I am in the NTSC area :(
