-   Special Mounts and Applications (https://www.dvinfo.net/forum/special-mounts-applications/)
-   -   Manfrotto 394 Loose (https://www.dvinfo.net/forum/special-mounts-applications/506263-manfrotto-394-loose.html)
Tariq Peter March 21st, 2012 09:49 AM
Manfrotto 394 Loose
3 Attachment(s)
Hi,
I have the Manfrotto 394 RC4 Low Profile Rectangular Rapid Connect Adapter With 410pl Plate. What is annoying the hell out of me is the bottom which attaches onto my 501pl. Because there is only 1 bolt to attach the two it keeps getting loose no matter how tight I tighten it.
There are see two small holes on either side of the plate (pictures attached) and was wondering if anybody knew if I could use them to help me secure the plate even further.
Richard Davidson March 21st, 2012 07:24 PM
Re: Manfrotto 394 Loose
How about Locktite on the threads, that should hold it tight. The other holes don't look threaded.
Jan Steinman October 13th, 2019 06:58 PM
Originally Posted by Tariq Peter (Post 1722213)
Hi,
I have the Manfrotto 394… it keeps getting loose… There are two small holes on either side of the plate… if I could use them to help me secure the plate even further.
These holes are ready to be tapped with a standard 1/4"x20tpi tap.
I use this QR system on just about everything I own, and the first thing I do when I get a new base plate is to thread those holes! I bought a box of 1/4"x20x1/4" long "grub screws" (set screws), and with two of those, you can bind this plate very tightly to any tripod mounting surface, so it won't rotate or work itself loose. I also add a dab of blue LocTite™ to the grub screws, so they won't work themselves out with vibration.
(Yes, I know this thread is years old, but if someone finds it in a search, at least they'll have the answer.)
Will Hopkins May 15th, 2023 06:37 AM
Yup, even years later still this helped. Thanks.
