-   Sound Devices PIX series Recorders (https://www.dvinfo.net/forum/sound-devices-pix-series-recorders/)
-   -   PIX240 Endurance (https://www.dvinfo.net/forum/sound-devices-pix-series-recorders/502600-pix240-endurance.html)
Terry Martin November 12th, 2011 02:07 AM
PIX240 Endurance
This was a test of recording capacity of a PIX240. With two new Sony 770 (4200mAh) batteries and a Samsung 470 series 256 gig SSD. Recorded a HMC150 HDMI to the Avid DNxHD 145 codec, with two live 48V mikes. Found 3.6 hours of capacity in the SSD, but only 2 hours of battery runtime.
Ned Soltz November 12th, 2011 05:52 AM
Re: PIX240 Endurance
The Pix consumes 28 watts. One way to conserve battery is turn off the display when you don't need it. I am powering mine via D tap from either Anton Bauer or Switronix battery for EX.
Chris Dickinson December 8th, 2011 11:04 AM
I've had similar results with non-Sony NP-F970 equivalent - about an hr recording per battery. I will probably default to using my Anton Bauers, and just use the smaller batteries as back-up most of the time...
Terry Martin December 9th, 2011 03:19 AM
I got a pair of Pearstone 7200 mAh batteries, and now have 3.5 hours of run time.
