-   Sony XDCAM PXW-FS7 / FS5 (https://www.dvinfo.net/forum/sony-xdcam-pxw-fs7-fs5/)
-   -   FS5 New FW 1.1 early Xmas (https://www.dvinfo.net/forum/sony-xdcam-pxw-fs7-fs5/530709-fs5-new-fw-1-1-early-xmas.html)
Olof Ekbergh December 22nd, 2015 09:04 AM
Sony?s Christmas surprise – FS5 firmware version 1.1 available for download
Olof Ekbergh December 22nd, 2015 03:28 PM
Re: FS5 New FW 1.1 early Xmas
The update went very smoothly. About 4 minutes on a MBP.
Just follow directions precisely.
Use AC power, I used AC on UPS just in case of power outage, we are having a storm here. I also removed the battery.
Remove your SD cards, this is in the instructions.
Also if you did any customization, make sure you save the profile to an SD card before updating as everything is reset including time/date. I had a bunch of PPs I was playing with, and they restored fine from the SD card, I only reset my region and time after the update. The cam profile even saves your custom button assignments/iso settings etc, and that worked fine as well after restoring.
Merry Xmas everyone.
