Series 7, EX-L96 Battery on F3 Problem
3 Attachment(s)
Hello Guys. I bought 4 Series 7, EX-L96 Battery with PT-XF3 cable using it for SONY F3 and NanoFlash, But When i Switching on Camera there is Battery Error Sign. I attached advertised photos but it dos not work like that. has anyone any experience? On My old EX 1 this batteries works with cable connection perfect but without it there is battery error too. ITS OK for working.
Re: Series 7, EX-L96 Battery on F3 Problem
Sorry Guys. need to remove DC PIN and everything works. Thank You! :)))
And don't forget to plug the DC pin back into the battery when charging!
I placed an order for the Switronix battery and have yet to receive it, however, I wonder if you could clarify the "DC pin" removal ... where on the battery is the pin located? Thank you in advance. |
It's the EX1/3 style power connector that's at the end of the little wire that wraps around the back of the battery. I bought an adapter (from NanoFlash.net) that goes from that power connector to 4-pin XLR female, so I don't need to cube out of the power tap plug to be able to run the F3 and NanoFlash simultaneously off the same battery.
Thank you.
| All times are GMT -6. The time now is 07:09 PM. |
