-   Sony XDCAM PMW-F3 CineAlta (https://www.dvinfo.net/forum/sony-xdcam-pmw-f3-cinealta/)
-   -   Reports of broken pins on F3 PL adapters (https://www.dvinfo.net/forum/sony-xdcam-pmw-f3-cinealta/497531-reports-broken-pins-f3-pl-adapters.html)
Chris Medico June 22nd, 2011 02:40 PM
Hey guys,
I got a report today from a local shooter in the area here asking about if all the pins were OK on the PL mount. Things are OK on mine since I don't use it.
Anyway, They have the F3K package and started getting lens communication errors. A quick troubleshooting session determined the problem to be a broken pin on the PL mount. There was a second pin that was slightly bent and when straightened it also broke off. Only the Sony PL lenses have been used with the camera.
I've not seen the mount in person yet but if I can get my hands on it I'll post some pictures of it. They were going to call Sony to see what to do about it.
Everyone keep an eye on your mount and make sure nothing is going wrong.
Alister Chapman June 22nd, 2011 06:58 PM
Re: Reports of broken pins on F3 PL adapters
Sounds very strange as the mount should never rotate or twist so there is nothing in the way the mount is fitted or removed to cause a bent pin other than operator error.
Peter G. Johnson July 11th, 2011 01:31 AM
Hello. I had the same thing happen to my F3. At least one or two pins (out of the set of four) have slightly bent. I managed to straighten them, however it didn't matter how 'careful' or how 'clinical' I was, the same pins bent again days later. So I didn't take it any further. Just as I also gave up with the issue of dust finding its way behind the blue optical port.
It's a great camera but it has some shortcomings.
(1.) View finder is flimsy. I have already read of one which has broke.
(2.) Optical port should be sealed. It's just a cheap, plastic frame held by four small screws.
(3.) The outward pins on the PL mount are easily bent.
(4.) Attachment of a lens is very awkward. (The safest method is sitting the camera face up first.)
Brian Drysdale July 11th, 2011 04:02 AM
PL mounts are usually stainless steel (the RED Epic M uses titanium), are they using a "softer" metal on the F3 PL mount?
Chris Medico July 11th, 2011 11:07 AM
Peter, could you possibly take a photo of the problem and post it for us to check out. I wasn't able to get any images of the local guy here that had the problem. I've not had the problem because I'm not using PL lenses at the moment.
If you can't post them on the forum you can email them to me and I'll be glad to post them for you. trackgeeks at gmail.
Nate Weaver July 11th, 2011 12:39 PM
I don't mean to be argumentative, but PL mounts have been in use for a long time (25 years or so), and they've stood the test of time.
It's possible to get very fast with lens changes and not muck anything up. You should watch an experienced 1st AC on a movie change primes at sunset. Like a zillion other things, it just takes practice.
Peter G. Johnson July 11th, 2011 07:31 PM
1 Attachment(s)
Here is a picture as close as possible. You can see that the third pin is bent and therefore stuck. (This is the one which takes the Arri style lenses?) I mean I'm not really worried anymore. I wouldn't even entertain the idea of purchasing an expensive lens (ie) Cooke, Zeiss. I bought the PMW-F3K, so the lens are fine.
Brian Drysdale July 12th, 2011 12:49 AM
Regardless of the the broken electronic data pin, you seem to have a lot of wear on the PL mount retaining/locking ring. It's what you'd expect to see on an older camera rather than one that's nearly new.
I'd assume those contacts are for Cooke/i and ARRI LDS, so unless you're going to be use those features.it may not even affect you in practise, however, it shouldn't break in such a short time.
I'd get in touch with your dealer, and try to get a replacement PL mount, (as Nate mentioned) it should be very easy to change lenses with a PL mount. You may have a machining flaw on yours.
Alister Chapman July 12th, 2011 12:49 AM
Looking at the scrapes in the anodising on the outside of the locking ring, I would say that someone is less than careful when swapping lenses.
The Sony lenses use the cooke interface for iris and focus information in the LCD.
Peter G. Johnson July 12th, 2011 02:59 AM
Thank you gentlemen for the 'alluding' comments.
As I have already strenuously enunciated, I do look after my gear, short of wrapping it in cotton wool. I change the lens frequently depending upon what sort of scene I'm trying to represent and I do it in a very clinical way.
As I have also stated previously the kit lens don't go on all that easily and no matter how careful I've been there is one pin out of line. If I had been somehow heavy handed with the mount, then wouldn't all of the pins have been bent?
I'd better stop here before I start making alluding comments myself!
Brian Drysdale July 12th, 2011 03:22 AM
The lenses should go on easily. The PL mount is designed to take heavy 35mm cine zoom lens without any problems, during filming this is usually done with the camera mounted on the tripod head. However, if you're finding it "sticky" in operation, I'd get your mount checked out in case it's a bit out of tolerance.
Another thought: it could be that the PL locking ring end stop isn't allowing the ring to rotate open enough, so fitting the lens becomes difficult and it binds as you put it on.
Peter G. Johnson July 12th, 2011 04:20 AM
I'm using any one of the three kit lenses which came with the camera (ie) 35mm, 50mm and 85mm. They are extraordinarily large and bulky but not very heavy. My common practice is, if something isn't fitting correctly, then stop and reassess.
I read the manual from cover to cover before attempting anything, including months and months of reading forums before deciding to purchase the F3. I've owned several cameras previously, including most recently a Canon XHA1 with a Letus Extreme, which served as an excellent learning tool for a more high end camera. By the way, all of this equipment is in pristine condition.
My apologies, but I was sensing some arrogance and a 'cheap shot' in another comment.
Anyway, aside from the issue with the pins, the camera is working fine. I'm perhaps too over critical with what I expect from an expensive piece of technology. Thanks for your suggestion.
Brian Drysdale July 12th, 2011 05:02 AM
These connectors and PL mounts should last for years in regular use on a professional set. If they're tending to break and have lens mounting problems with careful use I'd have them checked out under your warranty.
Morton Molyneux July 12th, 2011 07:37 PM
If you have a look at the mount on any of your lenses you will see there are 8 small recessed screws to hold the mount to the lens. They almost line up with the pins. It might have been possible to try to mount the lens in an incorrect position and rotate it to line it up and have one pin catch in the screw recess and get bent. Which would explain why one and not all got bent.
Just a thought from some one who was a mechanic in a previous life.
cheers
Morton
Alister Chapman July 13th, 2011 07:37 AM
I'm sorry if you found my remark as condescending, but there shouldn't be gouges in the anodising on the outside face of the PL locking ring. This suggests that a lens has been sitting on top of the locking ring and rotated or twisted into place, the lugs on the lens gouging the face of the locking ring in the process. The position of the gouge/scrape in your picture is exactly where the lens lugs would hit the face of the ring. Rotating or twisting the lens round into place like this can damage the pins as both the lens and locking ring may move together and then when the lens "drops" into the mount it may still be rotating and as the locking ring may be in the "closed" position as opposed to "open" the lugs may fall on the connector pins and bend them. The outer face of the locking ring shouldn't be making contact with anything and receiving such damage. I've had my F3 since Feb and my locking ring looks nothing like that, there are no marks on the outside of the ring. The locking ring should be turned fully counter clockwise and the lens lugs visually lined with the locating pin in the mount and the lens inserted straight in. There should be no need to rotate the lens by more than the tiniest amount just to get the lug to engage with the locating pin, then the locking ring is turned clockwise to close and secure. At no point should the lens lugs be hitting the outer face of the locking rig. If they are your doing something wrong or your PL adapter has a serious problem.
The only other way that I can see that these pins may be bent is if the PL mount locking ring is the "closed" clockwise position when an attempt to insert a lens (or the dust cap) is made and then both the lens and locking ring are rotated anti-clockwise together. The Sony lenses (and other LDS equipped lenses) and dust cap have a cut-away for the pins, if this is dragged over the top of the pins by twisting both the PL locking ring and lens/cap together, this could damage the pins. But frankly this is not a "fault" with the adapter, but operator error, plain and simple, the user should not be rotating the lens relative to the mount, it should be guided directly into place.
I expect many people coming from B4 2/3" broadcast lenses to PL mount will find it tricky. A B4 lens just sits on the mount until the locking ring is tightened, The design of a broadcast zoom makes it pretty obvious which way up it goes. PL on the other hand is quite different, for a start there are several possible lens orientations and very often the end of the lens is a snug fit into the the mount requiring precise alignment before it will slip into the mount and locate correctly.
Robert Moore July 13th, 2011 08:05 AM
There is a fairly decent view of mounting the PL Sony lenses on F3 by Philip Johnston.
See the following video at 10:00 -
Sony PMW-F3 REVIEW By Philip Johnston On ExposureRoom
Notice the lens does not move at all...only the adapter flange as Alister has described.
Good news is that the PL mount adapter could be replaced...so no lasting damage to the camera itself?
Bob
Brian Drysdale July 13th, 2011 09:58 AM
The PL mount is pretty much the standard modern film camera mount, the other one being Panavision's PV mount. These together with the old Aaton and CP mounts are based on the Mitchell BNCR mount design, although the dimensions of all these mounts are different. In each, the locking ring rotates locking the lens, which has a notch (or notches) that locates onto a pin on the camera mount. You have to ensure that the lens is flush to the camera lens mount and the pin engaged before rotating the locking ring.
You can see the layout of the electronic pins here:
http://www.fdtimes.com/news/arri/coo...-and-arri-lds/
Peter G. Johnson July 13th, 2011 06:27 PM
Thank you for your reply, Alister.
Robert actually stole my thunder. I was going to refer to Philip Johnston's video a few days ago. At 10:16 he conceded that on first inspection he couldn't figure out how to get the lens off and also he noted the small notch on the Sony lenses which is used as a guide for lining it up with the mount, so I assumed that Sony's design with this camera might be different to that of a common PL mount found on other cameras. That small notch is the first thing that I look for when mounting a lens.
I may have also opened a can of worms by posting a picture of my mount, but I did so at the request of Chris Medico who asked me to take a photo as reference.
And speaking of Chris, I'd like to see one of his photos posted for comparison.
Robert Moore July 13th, 2011 06:58 PM
Hi Peter,
I think the good news may be that the mount is replaceable...is this the case?
I assume that if the Sony PL adapter is replaced you have essentially a pristine camera....which is great news. I think that the ability to shuck an adapter every so often is part of the entry price...I would prefer that to sending my camera off to Sony National for an upgrade.
I posted on another site that I just returned a "NEW?" MTF adapter that was mailed to me from a major NY LA retailer that looked like it was dropped from a C130 Hercules onto the tarmac from 15000 feet. Major gouge on the camera interface side and dings on the body in two places.
Needless to say they will not be seeing any of my purchases in the future.
But again ... adapters are expendable...and occasionally out of spec. Get a new one and keep shooting.
Bob
Peter G. Johnson July 13th, 2011 09:18 PM
The PL Mount comes with the new F3 cameras, but this problem with the pins isn't a big deal, just the inconvenience of having to make a long trip back to the place where I bought the camera from, discussing the issue, arranging for a replacement and waiting who knows how long. I live in Australia and specialised camera shops are far and few between.
It's also very uncommon here to see anyone walking around with a serious camera. I get often stopped in the street with questions like "Will I be on the news tonight?" or "Who are you spying on?"
You'll be interested to also know I had a similar problem with a PMW-F3 adaptor. I ordered one for Nikon lenses. After waiting THREE weeks from date of payment it came in the mail today. They sent me a CANON one instead. Now it's on the way back as I speak.... another three weeks perhaps?
Thanks for your reply, Bob.
Nate Weaver July 13th, 2011 10:02 PM
Only problem is that the Sony PL adapter is $990-odd dollars if I recall. I saw this in the Sony US service parts catalogue online.
Peter G. Johnson July 13th, 2011 10:58 PM
Well, if it's not covered under warranty, I won't be pursuing it. Besides, those communication pins are only useful if you use those outrageously priced lens from Cooke or Arri.
What is the address for the sony service parts catalogue?
Alister Chapman July 14th, 2011 12:27 AM
The pins also work with the Sony lenses, providing iris and focus data.
The notch is normal and all PL lenses have a notch in each mounting lug.
Brian Drysdale July 14th, 2011 12:29 AM
Looking at the photo, there's a good chances are those pins on the PL mount are replaceable. Alistair mentions that the Sony lenses also use the pins, although perhaps these use the other set, since there are two sets of pins on the camera's PL mount.
Chris Medico July 14th, 2011 06:06 AM
I'll get some photos of my mount and post them. I have no bent pins. Another F3 owner here in North Carolina had reported bending pins on their mount. I was not able to get images of it before it was sent to Sony for repair. I've not heard back regarding the outcome of that situation. As soon as I find out more I'll be sure to post it here.
Nick Hiltgen January 29th, 2012 10:47 AM
Well After 8 months of careful use I sent the camera out on a rental to one of my clients and of course the mount came back with a busted pin and no communication with lenses. I really don't understand how people don't get it.
I immediately became suspicious when the thumb tighteners on the PL mount side were broken and bent, looked into the pl mount and saw the bent pins, then noticed no communication with the lens and confirmed it. I'll be sending the pl adapter to sony service I just wonder if I need to send the whole camera in, probably not a bad idea so that they can check it out for any other damage.
I haven't seen the cost on here, so I'll post the result of the fix (that the client will be paying) so people can know approx. how much to pay to fix it.
Peter G. Johnson January 30th, 2012 11:37 PM
They don't repair PL mounts, Nick, at least not here in Australia. They just replace them, at around $1100. I wonder what you do then, with an otherwise functioning PL mount?
Nick Hiltgen January 31st, 2012 02:02 AM
Ha!well that'll be interesting. Seems a little absurd to pay 1100 bucks for a .01 cent broken pin.
