-   Sony XDCAM PMW-F3 CineAlta (https://www.dvinfo.net/forum/sony-xdcam-pmw-f3-cinealta/)
-   -   60p resolution hit? (https://www.dvinfo.net/forum/sony-xdcam-pmw-f3-cinealta/492349-60p-resolution-hit.html)
Daniel Doherty February 27th, 2011 11:09 AM
60p resolution hit?
On the Sony product page it states that the resolution for recording 60p (59.94) is 1440 x 1080. Is this normal?
Phil Lee February 27th, 2011 11:46 AM
Re: 60p resolution hit?
Hi
Not normal, other camcorders manage 1920x1080 just fine at 50p/60p.
Just a restriction imposed by the hardware I expect.
Regards
Phil
Bob Willis February 27th, 2011 11:49 AM
There has always been some kind of resolution trade off for 60p with Sony and Panasonic cameras. Depending on the camera each would handle the resolution change in a different manner. Many would use the 1280x720 resolution for 60p. Some would compromise the codec rate.
So yes this is normal or common.
Andrew Stone February 27th, 2011 04:20 PM
I assume this is after a camera is upgraded with the firmware to be put out in April (or thereabouts) but is this for in camera recording or is this to the 10bit 444 recorder that Sony is putting out.
I recall that 60p was to be at full HD raster of 1920 by 1080 with the 10bit/444 recorder not the squished aspect ratio they used for HDV based material.
Andy Shipsides February 27th, 2011 09:37 PM
The camera can already output 1080 60p over dual link with no firmware needed. It just cannot record that in full raster on the cards. It seems like the 35mbps cap is hard set in the Xdcam Ex world.. So Sony fit the 60p in by reducing resolution. The F800 does something similar with a reduced vertical resolution. Now if only their was an affordable 1080 60p external recorder.
Andy
Daniel Doherty February 27th, 2011 10:15 PM
Andy,
Can you confirm that the 60p coming from the dual link is full 1920 x 1080 and not the 1440 x 1080 as stated on the Sony product page?
Daniel
James Houk February 27th, 2011 10:35 PM
You're misreading a recording specification for XDCAM-EX as being the same as a camera output specification. These things are not the same at all.
http://ws.sel.sony.com/PIPWebService...p%20Manual.pdf
Bottom of page 20, in regards to the dual link output (which can only be activated when in HQ 1920 59.94i recording mode):
NTSC Area : Port A: 1920 × 1080/59.94P@1.5G Port B: 1920 × 1080/59.94P@1.5G
What does this mean? If you set your SxS cards to record 1920x1080 59.94i, then you can simultaneously instruct the camera to output a 1920x1080 59.94p signal over Dual Link HD-SDI
Daniel Doherty February 27th, 2011 11:01 PM
Ha, forum tag. I responded to your post on the other forum. You're right, I was misreading the product page but that also had to be a typo.
Andrew Stone February 27th, 2011 11:06 PM
Well we'll just have to wait and see at NAB. Almost no point in speculating except for amusement. Sony reps have leaked out some vague info but not enough to hang your hat on and I am sure they will be treading this one very carefully waiting for announcements from others before releasing any info on pricing. Right now there are only a couple of reference points for them to base their pricing but obviously this is going to change within the next 8 weeks.
Andy Shipsides March 1st, 2011 09:33 PM
Yea. This forum got me going too.. starting believing it was possible. No 60p recording in 1440 or 1080 right now.
However I found that if you set the camera to 1080 59.94i and change the output to Dual Link... then you will get a 1080 60p output. No firmware needed. Now you just need a CineDeck or something similar to record it. :)
Timur Civan March 2nd, 2011 01:03 AM
eye heart Cinedeck.
Cant wait to buy one.
Peter Moretti March 2nd, 2011 05:08 AM
Any idea on how color accurate the monitor is? Can it compare to a TV Logic or samllHD? Also, does it record ProRes 4:4:4:4 or only uncompressed 4:4:4?
Thanks much!
Aaron Newsome March 4th, 2011 05:43 AM
I have an F3 and a Cinedeck extreme. I'll give it a try, 1080 60p.
Aaron Newsome March 4th, 2011 10:32 AM
Hi guys. I'm happy to report that the 1080/60p recording with the F3 and Cinedeck works very well. After reading this thread, I was compelled to do a test. I conformed the 60p file to 23.98 for a nice slow motion effect.
To clear up some confusing things I keep hearing posted here and there in forums.
1.) The output at the dual link SDI is full raster 1920x1080
2.) This does not require a firmware upgrade (recording 4:2:2 only, no S-log)
Let me know if you have any questions.
Daniel Doherty March 4th, 2011 10:48 AM
Aaron,
That's good news. Thanks for doing the tests. On a side note, have you had any trouble with the Cinedeck overheating? I'm considering a purchase.
Daniel
Aaron Newsome March 4th, 2011 10:59 AM
Hi Daniel, the only time you'll be able to overheat a Cinedeck is with fan control set to low and the take is extremely long.
The only reason to use fan control low, is when you are recording audio and you don't want the fan noise to be picked up by mics. I do a lot of music videos, so I'm not recording audio at all. When I do film work, takes are short, so again not an issue.
I've had to leave the Cinedeck at home only for a few shoots. I did a documentary where there were multiple interviews that were REALLY long, like 1 hour takes! The cinedeck would have been no good for this, unless I put the fan control on high and put it in another room.
I don't consider overheating an issue on the Cinedeck at all.
Daniel Doherty March 4th, 2011 11:10 AM
Thanks Aaron! The Cinedeck is very tempting. Have you had any other issues with it?
I'm going to wait and see how much the new Sony recorder will cost (plus 1TB memory) before I make a decision. Until then, my Ki Pro will tide me over.
-Daniel
Steve Kalle March 4th, 2011 11:39 AM
The Cinedeck's LCD is not very high quality. When I used 1:1 pixel, I was shocked to see such low quality.
Aaron Newsome March 4th, 2011 12:02 PM
When I bought the Cinedeck, there was nothing that could come close to it for anything less than about 35K.
It allowed me to record 4:4:4 uncompressed from my Viper, untethered (recorder mounted on camera), all on battery power in the field. Read that again. Not a whole lot of recorders can do that at anywhere near this price point. Plus I really love the Cineform codec. The recent adding of the Prores codec is welcome too.
However, that was over a year ago. I think at NAB you'll finally see some 4:4:4 recorders that can compete with the Cinedeck on features and cost. The two recorders that I'm thinking of already address my main concerns with cinedeck. That includes size, weight, power consumption, windows based OS.
Funny thing though, neither of those recorders have a screen at all. Most recorders don't. I certainly don't think I need a screen in my recorder. I'd miss the waveform but that's about it.
Honestly though, if I didn't need 4:4:4, I'd have never bought a Cinedeck because my Flash XDR (or a nanoFlash) is a fine recorder all by itself.
Ryan Koo March 4th, 2011 04:04 PM
Aaron -- would love to see the footage!
Steve Kalle March 4th, 2011 08:27 PM
Aaron,
Don't get me wrong, I'm not saying the Cinedeck isn't worth the money. It is just shocking that an $11,000 recorder doesn't have a good LCD when the makers tout the LCD as one of its great advantages. In fact, I am jealous that you have one and a true 444 camera to use with it.
Zoran Krstic November 22nd, 2011 03:26 AM
Hi Aaron,
Which codec you choose at 'input' tab for 1080/60p?
My Cinedeck EX cannot record in any codec except Cineform (422/8bit) at 1080/50p@422.
Thank you in advance.
Aaron Newsome November 27th, 2011 06:32 PM
That's corect. The Cinedeck only record 1080p/60 with 8bit Cineform Codec only. I've been told that other codecs should allow it soon.
