-   Sony XDCAM PMW-F3 CineAlta (https://www.dvinfo.net/forum/sony-xdcam-pmw-f3-cinealta/)
-   -   Street Price for SR-R1? (https://www.dvinfo.net/forum/sony-xdcam-pmw-f3-cinealta/490567-street-price-sr-r1.html)
Peter Corbett January 22nd, 2011 07:06 PM
Any word on what the price will be for the R1?
Dave Sperling January 22nd, 2011 07:42 PM
About an hour into the Rule F3 presentation video, Peter mentions that the price will be surprisingly affordable. Of course that may be partly in comparison to what the current costs are for a SR field recorder.
The other question is of course the cost of the memory cards. Think about a card that holds about 15x as much data as a 64GB SxS card, and is four times as fast. What cost multiple would you expect? I can't venture a guess.
Andrew Stone January 22nd, 2011 09:30 PM
I think the pricing will be in the context of all relatively well known and existing field recorders, not just the SR recorder for Sony's SR series cameras. Surprising affordable in my books would be $6 to $8 grand for the recorder and $12 grand when you thrown in a reasonable amount of memory cards. A few things to keep in mind that should be playing into their pricing. One is the total cost of a usable kit in relation to a RED One camera package. Two against the cost of the F3 paired with a third party recorder like the Cinedeck which comes with a large feature list and is showing up more and more on sets. Third will be the new entrants that come into the market in April which is why Sony will be holding their cards very close to their chest (in my estimation) until NAB is fully launched in April.
Steve Kalle January 22nd, 2011 09:48 PM
My question for the SR recorder is whether the data will be a downloadable file or will you still need to record it uncompressed through playback like the current SR tape. If the latter, then I don't see any benefit to using it over other recorders.
Nate Weaver January 22nd, 2011 10:04 PM
Mr. Crithary spoke of a coming QuickTime HDCAM SR codec, which implies that HDCAM SR will soon be as easy as XDCAM to ingest and work with.
For that codec to be of any use, you'd be bringing in the fils straight from the card, etc etc.
Dean Harrington January 23rd, 2011 07:42 AM
my 2 cents ...
$3,000 U.S.or less .... why you may ask ... because Sony has got a plan and that plan is geared toward killing the scarlet or red ligh as it's now calledt!!!
Henry Olonga January 24th, 2011 05:49 AM
In another post someone mentioned he had been told sub 20K at a trade show I think. I suppose 3 K is sub 20 K but Sony has never been really known for 'affordability' in the traditional sense. They used to sell Qualia headphones for $ 2500!!
I wish it were $ 3000 but hmmmm I doubt it will be sub 10 K. It will be potentially in the same ballpark as the Cinedeck Extreme and that's around 10 K for the high end version but shooting to the venerated SR codec. If they are too expensive many may run to Cinedeck - Cinedeck gives so much more. LCD, Touchscreen, direct to edit capability with Cineform and much more flexibilty with codecs etc. If I had the budget Cinedeck is a no brainer if the SR-R1 is in the upper regions.
Or - get a Blackmagic Decklink HD extreme 3D and do a DIY job with a laptop and magma chassis ( or pci express to expresscard version 2 adaptor cards ) for about $ 3000. That will give you all that these guys give with slightly less portability.
The F3 is an amazing camera. Making me possibly even change my mind even about a RED Epic cam. I have compared all the available clips of the AF100, had some online footage of the F3 and even downloaded the RED Epic stuff newly released. I have graded them all in Cineform Firstlight and speedgrade and the F3 has something going on that is just magical that the others seem to miss. Clean, high resolution and the colours are just spot on. Paired to the SR-R1 recorder - I am sure that this will make many people very happy.
Peter Corbett January 24th, 2011 06:22 AM
Sorry Dean but that is hokkum. I'm reliably informed by a Sony rep (not related to the above post) that the price is closer to $20K.
Dean Harrington January 24th, 2011 07:09 AM
peter ...
Don't know about hokkum ... highly likely wishful thinking ... but I'd keep Peter Crithary's suggestion in mind that the price will surprise us. $20K ... bit much!
Buba Kastorski January 24th, 2011 11:02 AM
$3,000 U.S.or less
$3.000 U.S. will not be enough to buy one 1T media for SR-R1 , as for recorder itself for less than $3000 - not possible, I think it'll be where thay say it'll be - sub $20K.
good luck with that, fixed scarlet will outsell F3 and AF100 together; 2/3", powered zoom, 3K at 120fps RAW, under $10K - to kill that you need to offer something if not better, but at least comparable for less;
sensor size IS important, but it's not everything.
Steve Kalle January 24th, 2011 01:05 PM
There is no way either the Sony or Red will outsell the AF100 in the US. You just can't beat the Panasonic's price. The pre-sell numbers for the AF100 were huge.
Brian Drysdale January 24th, 2011 01:12 PM
I suspect the 2/3" Scarlet is aiming at very different markets. It'll be attractive to those documentaries that were traditionally shot on 16mm neg and more recently Digibeta and HDCAM, but are now under a lot of budget pressures.
The price may attract some of those productions that have been filming on 1/3" cameras, although the RAW post may prove an issue for those productions that shoot everything that moves. The Canon XF 300 series may prove a big draw for them.
Andrew Stone January 24th, 2011 02:47 PM
First to market is important as we have all witnessed over the years. Don't forget Sony will be issuing mid-year what is presently called the S35 NXCAM. This will be a competitor for the AF-100 and will have some decided benefits over it, not the least of which is a 10bit 422 HD-SDI port and a full S35 sensor, the same one that is in the F3. Things can change but Panasonic will certainly have a lot of momentum by then with the AF-100 (it already does).
Andy Shipsides January 25th, 2011 09:36 PM
I'm with you Brian. Outside of the fanboys, I'm not sure exactly where this camera fits. I can see the need for some nature folks, but the documentary crowd normally wants the shoulder mounted form factor, easy to ingest codec, and a variety of servo driven lenses. Or they put a bunch of easy to use, often fully auto enabled small cameras out in the hands of interns. And they want formats that are ready for broadcast. I have an EX1, it's a great camera for what I used it for, and I don't think clients that just discovered HD, will care if I have a a 3K or not. For narrative/commercial work the large sensor cameras will continue to rule. I'm all about the right tool for the job, and I'm just not sure where exactly the Scarlet is needed. Probably wrong on this one, maybe hundreds of people are waiting to get the slightly larger sensor and RAW recording. No doubt it will be a beautiful camera, and the price is nice, but what are we going to do with it?
Andy
Buba Kastorski January 26th, 2011 02:54 PM
Only time will tell
Steve Kalle January 26th, 2011 08:07 PM
Today I was informed by my local Abel Cine that they have pre-sold over 100 F3's which is very close to their AF100 pre-sales. She stated that the sales figures are getting close to the AF100 but won't overtake it just due to the price. I'd love to see Red's sales numbers in a few months to see how much these 2 cameras have hurt their sales.
I wonder if these sales figures are good or great compared to prior new releases such as the EX1 because the economy is not doing as well as 2007 when the EX1 was released (or was it '08).
James Houk January 26th, 2011 09:38 PM
That's awesome!
I wonder how long it will take for all the preorders to get filled... from what I've heard some dealers are only getting like 10 in the initial shipments.
At least this isn't RED!
From my latest conversations I'm hopeful that we may see cameras shipping in the second week of February.
Steve Kalle January 26th, 2011 10:29 PM
I think that many F3 buyers are in a similar situation as me where we already are heavily invested in XDCAM EX equipment so purchasing a F3 doesn't include $2-4000+ in additional gear such as SxS cards, batteries, shoulder mounts, tripod and even a nanoFlash. The only thing I would need is a set of lenses and adapter (either Nikon or Alpha to F3 - probably Nikon at first due to all the great & cheap glass, then Alpha Zeiss lenses because they are the best I have used).
On a side note, the Abel Cine salesperson also said that they have pre-sold many Ki Mini's, however, she didn't mention whether the Mini's were included with any F3 orders.
For those who think 10bit capture will due something magical, I say that its a waste unless you have a pro colorist working on a Resolve or Lustre who absolutely needs the extra bits. I have had great luck with the 35Mb XDCAM EX and the 32bpc in both After Effects and Premiere Pro.
Andrew Stone January 27th, 2011 10:45 AM
Steve, good points however I would not consider using the F3 without either a 3rd party monitor or a relatively new Cineroid EVF.
Seems a lot of people are going for the SmallHD DP6 these days. There is also the TV Logic WFM-056WP which has been getting a bit of attention recently as it uses the same LCD panel as the SmallHD but it has a scope package built into it. There are also a couple of offerings from Marshall that are good as well such as the daylight viewable LCD651STX-3GSDI-AB (pricey for some) or the more affordable V-LCD70XP-3GSDI-SB.
And of course you will need a monitor arm. The Ikan MA206 can be had at B&H for around $70.
As far as external recorders go, I have not heard of even one Ki Pro Mini in the field yet. The first thing I would want to know about is how good the heat management is and second how loud the fan is under normal operating conditions.
Jose Rodrigues September 28th, 2012 06:36 PM
Re: Street Price for SR-R1?
hello everyone, i am looking for the sr-r1 recorder, however not alot of distributors out there that carry them. i did see two on eBay. one going to 7500 brand new and the other for 9000.00 do you guys think its worth it?
Duke Marsh September 29th, 2012 10:28 AM
Alister Chapman and several others have gone the Gemini (by Convergent Design) route instead. The Gemini sells for about $6,000 at B&H and handles more codecs.
When you look at the real price you have to look at the cost of the media too. The Gemini uses SSD drives which have dropped tremendously in price.
The SR-R1 is using S15 SR media. Much harder to find and much more expensive.
Jose Rodrigues September 29th, 2012 01:24 PM
thanks for the reply^^^. ill check it out.
Ryan Hollings September 30th, 2012 09:21 AM
Also check out the cinedeck EX.
I know the gemini uses 1.8 SSdrives, which are still pretty pricey, and I "believe" they recommend to use their branded SSds.
The cinedeck uses 2.5 inch drives, ($120 for a 128gb), can record DNxHD, Cineform, Prores (every flavor), IMX XDCAM 50 or 35, Uncompressed, etc.
I've had one for a yr, and it has been a great addition to the F3.
Ryan
Jose Rodrigues November 22nd, 2012 07:17 AM
Am Selling my Sony SR-R1 if anyone is interested in the Classifieds
