PMW F3 sensor cleaning
This might seem like a mundane question, but it's important to me, and I haven't seen an answer yet.
How are we going to keep the F3 sensor clean? Has Sony said anything about this? I've always been a big fan of Sony's designs, but their service department is another story. Won't the large sensor need cleaning on a regular basis? Is this something that a user can do without violating the warranty? If not, do I have to send the camera back to Sony (i.e., kiss it goodbye for a lengthy, undefined period of time)? And, as long as I'm posting niggling little questions: does anyone know if Sony plans to include a few basic accessories with the camera? Battery, charger, etc? I've ordered one without the lenses ( I have a drawer full of Nikon glass and an MTF adapter on order )--don't know if I even get a body cap with it. |
It won't be any different to any other removable lens camcorder. The sensor itself is buried well behind the optical port and filter wheel, so in practice the only thing you can clean without full workshop facilities will be the optical port. This should also be the only thing that ever needs cleaning unless some bozo with canned air has blasted a ton of dust into the camera body (I've seen more camera wrecked by the use of canned air than any other single issue).
AFAIK the standard kits will not include batteries or chargers. These will be optional items. |
Thanks. Now that you mention it, I did read that the camera had a ND filter wheel. That must be pretty substantial, given the size of the sensor. Didn't realize that there was also an "optical port" between the sensor and the outside world. I've never done any critical testing, but the ND filter on my HPX-500 looks like it degrades the image, especially if I have the lens wide open. I'm curious to find out what happens with the ND on the F3.
You'd hope that anyone who can spend over $10k on a camera would know enough not to squirt propellant all over the sensor, but I guess it's a big world out there.... |
Not that this is going to be an issue for many of us who plan to keep their EX cam around. |
Looks like a hand-held camcorder, sort of, but doesn't come with the extras we're used to getting with a little camera. Bigger, shoulder-mounted cameras don't come with batteries, so I suppose that's Sony's logic. I'm not crazy about having to buy another charger and batts. Has anyone seen a good way to put a brick on it?
Any one better than the others?
http://www.bhphotovideo.com/c/product/242075-REG/IDX_C_EB_XLR_C_EBXLR_V_Mount_Plate_with.html I've never had a problem with any IDX stuff in the past, thats why I went with this. |
The ND function is not a wheel type but instead, a pretty ingenous dual shutter that slides vertically in front of the sensor. Thierry. |
Ryan - the IDX adapter looks solid, just wondering how and where to attach something like that to the F3. For balance, I'd put it in back, but I hate to block connectors and card slots.
Thierry - Thanks for the clarification on the ND function of the camera. Are there any diagrams or more detailed descriptions? Other than reducing the amount of light that hits the sensor, does this shutter have any impact on how the camera records motion? I'm really glad to hear that the ND isn't an actual filter--can't see how that wouldn't cause trouble... |
I have a zaucto base plate, with the rods, which I intend to use with the camera. I also have a redrock micro plate; http://www.bhphotovideo.com/c/product/690992-REG/Redrock_Micro_2_068_0001_MICROBALANCEPLUS_ACCESSORY_PLATE.html which I attached the mentioned adapter to one side, and on the other side just a v mount plate to hold a batt to power various other accessories, like monitor or a nanoflash. The plate is a little pricey, I am sure someone more handy than myself could've made one quite easily, but I had this plate for a little while thought I would put it to use. Ryan |
Wow. An dovetail offset cheese plate. That looks handy.
Looks like the F3 is going to need rails, one way or the other. I've got an assortment of stuff for my 5D, but now I'll have to find a good base plate for this camera. |
T. |
Thierry,
Don't you mean LARGEST aperture setting? |
Old photographer's rule of thumb--most lenses look best 2 stops down from wide open. I break that rule sometimes, for various reasons, but I understand what you're saying, Thierry.
When I made that comment about an "actual ND filter" causing "trouble", I was overstating things. Sitting here at the keyboard, I tend to get a little to get hypothetical. The ND filter on my 2/3" camera does visibly degrade the image when the lens is at 1.8. Now, I know I shouldn't be using that lens wide open, but sometimes I'll do it to get the limited DOF. I can't get away with that if I use ND. |
When we had the cameras in last month we cleaned the sensor easily. Not the actual sensor of course, but the glass protecting it. Once the PL adapter is off, it is easy to get to.
The way the ND filters role in is pretty impressive. We also liked the manual flange adjustment option, which we will learn more about in the future. It should be a very handy feature though. |
"Manual flange adjustment"? I'm curious about that. Can anyone give a few more details?
As I understand it, since Cine lenses typically do not feature back focus adjustment other than removing their mount and re-shimming the lens (something that I always sent my film lenses in to the shop to have done when required), this provides a way of fine tuning the flange distance of the mount. Obviously this is not something to be done casually in the field, but it does add a potentially needed capability to the camera (especially when using rental PL lenses or sharing a lens set between more than one camera.
Hopefully the manual adjustment will be a more a check before a shoot begins operation, rather than a between lens changes. The lenses should (in theory) be set up to a standard, rather than each camera.
Of course, if the mount is prone to thermal expansion, you may need the manual adjustment. |
Thanks, but I was just wondering about the particulars. Guess I'll have to wait for that.
