-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   PXW-X180 can shoot XAVC-Intra on SDXC cards (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/529585-pxw-x180-can-shoot-xavc-intra-sdxc-cards.html)
Paul Anderegg September 1st, 2015 04:57 PM
I did a full reset on my X180, and when it rebooted with my Sony MEAD-SD02 SDXC card adaptors inserted, it was set to XAVC-Intra 112Mbps. When I pressed REC, it worked! Yay!
The operating manual states that you need SxS or the XQD adaptor to run XAVC-Intra......maybe the new firmware released a few months ago changed that. It's a pleasant suprise though. i should mention I am using Sony OEM 64GB "94MB/s" SDXC cards with OEM card adaptors.
Paul
Jack Zhang September 1st, 2015 10:15 PM
Re: PXW-X180 can shoot XAVC-Intra on SDXC cards
This is because they support exFAT, which XAVC requires to run.
Make sure from here on out you get "U3" cards to ensure that 112mbps writes to it properly.
Terry Dennis September 7th, 2015 02:31 PM
that's brilliant is that the highest setting as i know nothing about codes
