change the shutter to 1/50
Hi, I have a Sony X160 and I would like to know how i change the shutter to 1/50. Is seems to be 1/60 and up , I have had it set to "speed" and PAL or NTSC no different. My X200 has 1/50 , 1/60 and so on, the Manual event shows the X160 has 1/50.
So the reason is i shoot footage for a Japanese Company In Australia, camera has to be set NTSC with a shutter of 1/50 to stop the lights flickering, has worked on the X200 for the past yr, yet i can't work this one out on the X160. Any one know ? Thx., (sorry for the double post in the wrong forum) |
Re: change the shutter to 1/50
Hi Robert,
Just got my 160 yesterday so still sorting it out. On body set Shutter to on. In Menu- Camera - Shutter - Mode= Speed. Shutter Speed= 1/50. |
Hi, Yes I worked ok but it only has 1/60 ? I am not sure why ?
That is strange, mine has all.
Maybe another menu setting that opens up more options? Ill post back if I find it. What Firmware version are you on? Im on V2 |
1 Attachment(s)
This is the most I could find.
1 Attachment(s)
This all I ses
But if you go over the right-hand column and select where it says "1/60", what options then come up?
What is your recording Codec? I saw this happen (force minimum 1/60) on the x200 when I changed from xavc 1080p25 to xavc 1080p50...
Maybe you have to select ECS frequency of 50.00? I couldn't get 1/30 on my X180 without using the 2 frame SLS mode. :-\
Paul |
I wonder if it's like the JVC 650 where "Shutter off" is actually 1/50???
Maybe do some tests and check what the metadata says in Catalyst Browse? |
Also take note of the "depending on the frame frequency" comment on page #66 of the manual, at least that's the page here that says the following: Set the shutter speed when Speed mode is selected. The available setting values vary depending on the frame frequency of the video format selected. Shutter Speed 1/32, 1/33, 1/40, 1/48, 1/50, 1/60, 1/96, 1/100, 1/120, 1/125, 1/250, 1/500, 1/1000, 1/2000 Basically what we used to do was shoot 60th second on PAL cameras when in the States or if shooting here for US or Japanese clients in NTSC we used to shoot at 100th as that was twice the mains frequency. Either way you minimize the 10Hz flicker off-set. This advice could be wrong but as I no longer have a 160 or 180 to physically check with I am just relying on the old grey matter and the PDF manual. Chris Young CYV Productions Sydney |
Dont think this is worth a new thread,
Just on my first full day with the x160, does anyone know why I can't get waveform to display with a HDMI monitor attached? |
1 Attachment(s)
