-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   Playing out EX3 clips (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/520251-playing-out-ex3-clips.html)
George Odell November 24th, 2013 12:39 PM
I've never had much luck playing out EX3 clips on my laptop. Perhaps it's to slow but I can play P2 clips with no issues nice and smooth.
Dell 1.6ghz, Pentium M, XP Pro-SP2, 512Mb ram
From inside Content Browser (have the trial version running) the clip appears to the right but stutters and stops.
Even tried to play just the clips from outside the Browser and still no luck. The clips are in MP4 format and I have QT 7 installed but I get an error if I try to play the clips by themselves.
Is my system just to darn slow for this or am I missing a codec or some other file?
Olof Ekbergh November 30th, 2013 09:58 AM
Re: Playing out EX3 clips
1 Attachment(s)
I think your LT is a bit marginal. More RAM may help but better CPU and GPU is definitely recommended. A fast healthy HD or SSD helps too.
This 4 core setup has absolutely no problems even editing and playing back several streams w/o rendering.
George Odell December 1st, 2013 01:07 PM
Thanks, but I till feel there is something else going on. I can play the mp4 clips themselves on my old Dell 2.4gz P4 machine using media player. They are out of sync audio wise but they play smooth. Do not have clip browser on it either.
And, as I said, PII cards with files at 100mbit/sec also work fine. XDCAM is only 35mbit/sec.
Still would like to know why they do not open QT7. Guess I'll keep working on it. Be nice to be able to
check a clip off of the camera in the field.
Chris Medico December 1st, 2013 02:39 PM
XDCam is a more complex compression method and requires more computer horsepower to play back. DVCPro100 is much simpler and easier to play back.
A single core pentium processor is below the minimum spec needed to play back XDCam.
If you try different software download a copy of VLC Media player and give it a go. If it won't play the file smoothly nothing will on your computer.
Edit:
You will need an addon for QT to play XDCam files.
Dave Sperling December 1st, 2013 04:54 PM
Back when I had a slow laptop I would use Clip Browser/ XDcam Browser to rewrap the selected clip(s) into MXF files which would then actually play surprisingly well using Sony PDZ10 XDcam Player. On the same system, Clip Browser would stutter and halt on the orig camera footage. Over the years I've also found QuickTime on slower windows machines anywhere from clunky to marginal.
As Chris suggests, VLC may be an option, though there are also sometimes issues with only hearing one of the audio tracks in VLC.
Of course my real advice is to move forward and get a fast laptop with USB3 - Doing so has cut down my SxS transfer times considerably.
George Odell December 5th, 2013 04:41 PM
Thanks guys.
I see your point. Christmas is coming : )
Doug Jensen December 9th, 2013 07:21 AM
That's my advice too.
In fact, even though I am 100% Mac in all other ways, I just purchased a $350 11" notebook PC (Windows 7) last month for transferring client footage from the SxS cards to a portable hard drive in the field. It's got three USB 3.0 ports and runs Content Browser perfectly.
I have the computer insalled in a Pelican briefcase with the the Sony card reader and it takes up no room in my vehicle. I don't even need AC power and i's amazing how fast I can transfer the footage.
If you're shopping for a solution like this, make sure the computer has at least TWO USB 3.0 ports. A lot of them that I looked at only had one.
Here's the PC I got ,in case anyone is interested.
Amazon.com: Acer Aspire V5-131-2629 11.6" Laptop (Black): Computers & Accessories
