LED Interview lights
looking for a good pair of led lights for interviews other than litepanels. like all their other lights way overpriced.
would love to find some that have the 3200 built in, most don't. thanks jim |
Re: LED Interview lights
I've got one of these and like it quite a bit: F&V USA | K4000 LED Studio Panel
Daylight only version gives out double the light, but there is a bi-color available as well. About $400 each or $1100 for a set of 3. |
I'm using Dracast Pro Series LEDs that I purchased from Guy Cochrane at DVEStore based on his recommendation.
http://www.dvestore.com/dracast-led-500-video-light/ $495 for more LEDs with higher CRI (>93 instead of 85) than the F&V. I like them. The light is excellent, the dimmer works fine other than the fact it FEELS like it binds but you don't generally adjust light output DURING a take... The metal on the frame does seem somewhat flimsy to me but all-in-all a solid performer. I own 1 x 500 and 1 x 1000 (spot). I'll likely sell the 1000 and buy two more 500s. |
I have been using Cool Lights LEDs for pretty many years for a variety of jobs.
Shaun: Why are you considering the sale of your 1000 and relacing it with the two 500's. I am looking at both the Dracast and F&V's trying to decide which way to go. Is the 1000 equivalent to 1000 watts of tungsten? The 500's appear to be small in stature and I wondering how wbright hey actually get. This will be my first LED kit. Before seeing htis thread I actually stated another one in the photon section.
I recently bought a couple of YONGNUO YN-600 panels. They're about $150 USD on Ebay and run off Sony F970 batteries (about 150 mins runtime off two 6600mah batteries).
I'm sure they're not the most colour accurate lights but I've been totally happy with the performance so far. They're more than bright enough for outdoor interview setups. They come in a daylight balanced and 3200/5600k switchable model. |
After trying a variety of LED lights (many listed in this string) I have settled on the Westcott Skylux and love them. The color balance is spot-on 5600, with NO green cast. I have tested them compared to my Arrisun HMIs, and there is virtually no difference in color temperature. Westcott claims the Skylux is equivalent to a 1000w tungsten, but I kind of doubt that, however they are equal to my Arrisun 200 PAR HMIs w/ fresnel lens. Probably more like a 650w tungsten fresnel in actual output, but at 1/6 the power. These lights are more similar to a HMI type fixture than a LED panel like the Coollights or Litepanel. They can be used as a direct (but already diffuse) light source, or as I prefer, with a softbox and 1/4 stop diffuser scrim. VERY soft and complimentary light. You can also use a different reflector which accepts standard 7" honeycomb grids for even more control of the falloff. Barn doors and gels are also available. They are far, far more versatile than 'panel' light sources.
In addition to these, I am also extremely happy with my Westcott 'Ice Lights'. (google 'em) These are not very powerful, but Kino-quality light out of a small battery (or AC powered) 'wand'. VERY cool, VERY soft, and very, very complimentary and versatile. These lights are simply awesome. So far, these are the best most versatile and most importantly color-accurate LEDs I have used to date. The only drawback is if you need 3200 you're kind of out of luck or have to gel. They are only available in 5600. And no, I don't work for Westcott nor am I paid to endorse their products. I just am very impressed with what they have accomplished. |
| All times are GMT -6. The time now is 03:19 PM. |
