-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   Sony EX1 Power Supply Issue (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/518076-sony-ex1-power-supply-issue.html)
Mark Savage August 1st, 2013 04:43 PM
My Sony BC-U1 AC Adaptor/Charger is no longer providing AC power to the back of my camera. It IS still charging batteries. I figure the hard-wired cable connector is the issue.
A replacement unit is around $170. I rarely use the AC, but have a couple of upcoming gigs requiring it.
Is there a better replacement than the standard unit? Or a unit that just powers rather than charges?
I'm migrating shortly to a different camera, so am weighing the short term options.
TIA.
Paul Cascio August 2nd, 2013 06:12 AM
Re: Sony EX1 Power Supply Issue
I've found that I can charge batteries quite well with the cheap chargers found on Ebay. Had good success with 3rd party batteries too.
Mark Savage August 2nd, 2013 07:24 AM
Paul, thank you...
But my issue isn't batteries. It's the AC part of the supply that isn't working. It's charging just fine.
Chris Medico August 2nd, 2013 07:59 AM
Have you checked the switch? That I suspect would be the most likely place where a failure occurs. It could be a pretty simple fix.
Dave Sperling August 2nd, 2013 10:26 AM
If you do need to get a new unit, I'd recommend taking a look at the BC-U2. It can charge 2 batts simultaneously, or charge one while powering the camera. It also uses a separate (removable) cable to go from the charger to camera, I travel a lot, and carry both a BC-U1 and BC-U2 so I can charge 3 batts at the same time (of course I also use BP batts to power a field monitor, so I tend to go through more than I would with just the camera.)
Michael Sims August 2nd, 2013 02:45 PM
Just saw an AC power supply for EX1 on ebay for about $29. Do a search for Sony PMW to find it. Looks like a low cost solution.
Al Gardner August 2nd, 2013 03:32 PM
Thanks for that Michael,
I see a couple of them up there. Mine is working but a spare would help.
I think Mark and i were on the same job when his power supply went out if that's the same guy.
I loaned him my batteries for 3 days.
AC Adapter Charger for Sony EX3 EX1 PMW EX3 XDCAM EX Camcorder Power Supply Cord | eBay
AC Adapter Car Charger for Sony PMW EX1 PMW EX1R XDCAM SXS EX HD Pro Camcorder | eBay
