-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   On EX cameras, when both internal & external power is connected, which drains first? (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/517712-ex-cameras-when-both-internal-external-power-connected-drains-first.html)
Les Wilson July 11th, 2013 06:36 AM
I'm using an external battery on a shoulder rig with an EX1R. If there's also a SONY BP battery in the camera's battery slot, anyone know which will drain first, the internal or external source?
Jack Zhang July 11th, 2013 08:55 AM
Re: On EX cameras, when both internal & external power is connected, which drains fir
External. When there is power connected to the DC IN, it will drain that over the BP-U battery. Do be warned that there is no low voltage switchover when you do this so you must manually yank the DC IN to switch to the BP-U battery.
