Kensington adapter works with sandisk 128gB
Hi
Bought some sonnet card adapters to be able to use the Sandisk 128 gB SD cards (45mbs). Just tried the SD cards in my older kensington adapter and there is no problem ! 431 min. recording time !!! |
Re: Kensington adapter works with sandisk 128gB
431 eggs in one flimsy basket! Sorry, I couldn't resist.
Good luck with that. |
I use Sandisk 64 gigs in MXR EXTREME adapters. I use sandisk only and I'm afraid to go over 64gigs.
Until I experience a problem or lost footage, I have no problem using a technology :) Naturally I considered it when the Compact Cassete got 120 min recording time or when hardisks got from 4 to 12 gB or today when I still think there must be a limit when they make 4 tB hardisks instead of 3 tB. There are a lot of good things using an adapter with SD cards - like if I am on a job with my notebook and the SD card goes directly into a slot. SD cards are used in my GH3, my AG-HMR10, D800 - and maybe soon in my P2 equipment - so it is a standard - for the time being :)
1 Attachment(s)
I doubt you will stop using technology because of lost footage. I have had corrupt footage on the stock Sony cards in My EX1R.
I notice you chose Sandisk just as I did. And that's only because i believe all technology is not created equal even if it serves the same purpose. I think your comparisons to cassette tape and hard drives are a moot point. Totally different applications. But I applaud your willingness to embrace the technology. I shoot a lot of very long form work so I need larger cards. But there is a limit to how much egg I want on my face should i have a failure. And 64 gig while high anyway, is my current limit. I have 6 32 gig Sandisk Efilms MXR combos and 2 64 gig combos. And also a Sony 16 gig SXS that gets used the least. The only failure i have ever had was on the Sony and it was a small corrupt file on a shoot that I was able to just do a retake. I still trust the Sony the most for some unknown reason. I shoot a lot of conference video , that's roughly 6 to 7 hours a day across several cameras. I shoot during the day and offload at night. I no longer have to offload in the middle of a shoot. While I have some other brands such as Transcend and Patriot in my personal dslr, I only use the Sandisk Efilm MXR combo for paid work. |
If there ever was a reasonable argument for using SD cards with XDCAM camcorders, it lost all validity when XQD cards were introduced. If SxS cards are too expensive for someone, then XQD by far the next best alternative.
Ever since I split an SD-card in half while trying to pry it out of my GoPro camera, I consider these cards as suitable only for pure amateur use. This conviction is supported by the fact that none of my pro DSLR cameras use SD as their main recording device. Compact Flash and SxS are developed and made to withstand a professional environment, SD-cards are not.
One advantage SD does have over CF is the facility of a write protect switch. There seems to be evidence that a number of cases of corruption of cards once they leave the camera are due to spurious writes etc by other equipment. (That's true for all types of card.) At least write protect protects against that. |
So splitting a card in 2 or any other damage to the card is impossible. I'm not sure what you call amateur use but I get paid quite well when using these. I can go along with your belief that that they wouldn't work for you. But my experience and the experience of many others suggest otherwise. But I also understand the need to cling to a belief for no apparent reason. |
When the card never leaves the adapter, you have a point, Al. In all other cases I consider it too mechanically vulnerable to be reliable.
So are you able to use the MxR adaptor with the Sandisk SD card in the Sony reader, or are you using it with an express card slot? I am unable to read the MxR adaptor with Sandisk SD card combo with my reader so have to take the SD card out & insert it in my SD card reader. Regards, Bryce |
Oops, sorry, duplicate post
1 Attachment(s)
I use the Efilms adapter. My cards are never removed.
Ok, thanks for that, I hadn't seen that reader. So does this reader also work with the Sony SxS cards?
Thanks, Bryce |
Unfortunately it doesn't. My Asus laptop reads the Sony cards though.
| All times are GMT -6. The time now is 09:41 AM. |
