-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   Sony EX3 v1.17 HD SDI Out signal problem (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/513778-sony-ex3-v1-17-hd-sdi-out-signal-problem.html)
J.B. Reodica January 25th, 2013 11:23 PM
Ive got an EX3 that is getting a clean HD signal on its viewfinder, but on the SDI out the image is "foggy" and the blacks are completely washed out.
The problem persisted even when performing a "Reset all".
I've ruled out that it is NOT humidity/condensation, back focus, faulty ND filter, or any obvious lens or sensor issue.
Has this happened to anyone else? Anyone know of a fix?
Alister Chapman January 26th, 2013 03:07 AM
Re: Sony EX3 v1.17 HD SDI Out signal problem
I assume you've tried different monitors to rule out the monitor.
J.B. Reodica January 27th, 2013 01:54 PM
@Alister
Yes of course.
Ive fed a 20" CRT Sony HDSDI monitor as well as a Panasonic HD-SDI switcher both with the same result
Dave Sperling January 27th, 2013 02:03 PM
Is the recorded image good?
Have you tried looking at the component output?
Is the problem independent of whether the camera is in camera mode or playback mode?
J.B. Reodica January 27th, 2013 05:20 PM
@Dave
I will look into those aspects when I get to the shop tomorrow. thank you.
