clip numbers
My PMW500 goes up to 9,999 in the clip menu.. just wondered.. what happens after that.. ? back to 0001
I can put in a custom title,which I always do.. would that title automatically change ? eg add an A.. or a 1 when 9,999 is reached to avoid another "title" 0001 file.. ie same as the very first clip.. I know 9,999 is alot of clips but just wondered if anyone has an answer.. Thanks.. |
Re: clip numbers
When the clip numbers reach the maximum and start over again at zero, it won't change the alphanumeric part of the clip name. You'll have to do that yourself to avoid getting duplicate clip names.
You could easily answer this yourself by setting the number close to the limit and shooting a few clips to see what happens. |
Re: clip numbers
| All times are GMT -6. The time now is 05:26 PM. |
