-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   Filming in Finland Advice (FAO: Alister?) (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/512994-filming-finland-advice-fao-alister.html)
David Dwyer December 28th, 2012 01:38 PM
Sorry for the FAO thread but I know Alister has been Finland to film many times. I am after some advice and tips of the Do and Donts when out there.
So condensation is my biggest fear with a brand new Sony PMW-200 but I read when finished filming store the camera inside a Pelican case and seal it shut and if possible leave outside which will prevent the camera going from Cold to Warm and back again.
I want to try and film the Northern Lights - Can you recommend any settings for this?
I have a Portabrace Polar cover on the way which will keep the camera warm when actually filming. I have the heat packs for the inside of the cover. Also read not to switch the camera on and off in between shots?
Batteries will be kept close to me to prevent them from draining quickly.
Anything else I should be aware of?
Cheers,
David
Bill Ward December 29th, 2012 09:21 AM
Re: Filming in Finland Advice (FAO: Alister?)
Lonely reindeer? True story...I had a producer who was...umm..."propositioned" by a young reindeer at a Santa's Village reindeer enclosure in Alaska.
Other than that, looks like you're covering most of the bases, but Alister no doubt has more tips than any of the rest of us.
David Dwyer December 29th, 2012 09:55 AM
haha noted though I should be fine with that because I'm filming loud Rally cars so I would think the Reindeer will not be seen close to thr action.
Alister Chapman December 29th, 2012 01:29 PM
Condensation is the big deal breaker. When you take the very cold camera inside into a house/hotel/car you will get condensation. If the camera is very cold this can then freeze. If there is condensation on the outside of the camera, there will also be condensation inside and this can kill your camera. To prevent or at least reduce the condensation you can place the camera in a large ziplock bag BEFORE taking it inside. Then allow the camera to warm up to the ambient temperature before removing it from the bag. Peli cases are another option, but the large volume of the pelicase means there will be more moisture in the case to condense and the insulating properties of the case mean that it could take many hours to warm up. You can leave the camera outside provided it does not get below -25c. Below -25c you risk the LCD panel freezing and cracking.
Yes, leave the camera on between shots. The camera generates some heat internally and this will prevent many issues.
Other considerations are tripods. If outside in very low temps for more than 30mins or so the grease in the tripod will become very thick and may even freeze, so your fluid damping will become either very stiff or freeze up all together. Vinten and some of the other tripod companies can winterise the tripod and replace the normal grease with arctic grease.
Conventional rain covers become brittle below about -15c and can even shatter below -20c. The polar bear should be fine and will help keep the camera warm. Plastics get brittle at low temperatures so be very gentle with anything plastic, especially things made from very hard, cheap plastic. The plastic Sony use appears to be pretty tough even at low temps.
I find that the best way to operate the camera is by wearing a pair of large top quality mittens (gloves are next to useless below -10c), consider getting a pair of Army surplus arctic mittens, they are very cheap on ebay. If you can get Swedish or Finnish military ones these are amongst the best. I wear a pair of thin thinsulate gloves that will fit inside the mittens, i can then slip my hands in and out of the mittens to operate the camera. I keep a chemical hand warmer inside the mittens to warm my fingers back up after using the camera. The hardest thing to keep warm is your feet. You'll be standing in snow and conventional hiking boots etc will not keep your feet warm. If your feet get cold then you are at risk of frostbite or frost nip. Invest in or hire some decent snow boots like Sorel's or Baffin's. I have an arctic clothing guide here; Arctic Clothing Guide |
To shoot the Aurora you'll need to use either time-lapse combined with the Ex-slow shutter or S&Q motion at 1fps with the shutter set at 1 second. When I first used the EX1 to shoot the Aurora I was very pleased with the results. However things have moved on and cameras like the F3 or FS700 which are much more sensitive do a better job.
Simon Wood December 29th, 2012 03:02 PM
I have filmed in Finland a few times during winter (-30*!). Most cabins / houses have a sort of entrance room where everyone leaves their shoes - its usually not as heated as the rest of the house so its a good place to transition the camera.
Also have a look at those small cool-bags (like what you keep a 6 pack of beer in) and using it the same way as the zip-lock bag mentioned above.
Alister Chapman December 30th, 2012 03:55 AM
To prevent condensation you just need to keep the moisture away. An insulated bag will certainly help keep the moisture off but will also slow down how quickly the camera warms up. The use of the un heated reception/entrance room to store cameras is a good idea and is what we do too.
I've now started using small battery powered heaters of the type designed to work with radio controlled aircraft when I shoot the Aurora to prevent the lens from icing up. The heater can also be placed in the ziplock bag to warm the camera up quickly when you go inside.
HobbyKing Universal Heater System
A couple of places have opened up on my Feb 2013 Aurora expeditions due to a cancellation if anyone is interested. I'll be shooting with an F5 as well as some NEX5n's and an a99. We'll have a small motion control rig for time lapse.
David Dwyer December 31st, 2012 09:53 AM
Ordered my Polar Bear cover on Friday from Portabrace direct and it arrived today! Impressed with the shipping! Cover seems very warm and toasty and its easy to get in/out as well. Rain cover on the other hand is a bit pain, though I'm sure that is just user error.
I will look for some zippy tie bags and I'll do that.
The only other thing I need is the SXS reader, doubt Sony will have the USB3 version out before I go so I need to find something else as I don't want to spend the money on the older USB2 one.
Robin Probyn December 31st, 2012 01:00 PM
Re SxS reader.. then your only option seems to be the sonnet reader..
David Dwyer December 31st, 2012 01:09 PM
Thanks Robin though they are a little expensive for me. The Sony USB3 one should retail £300-£400 and they are £700. I'm looking at picking up the MXM Express USB2 one for a couple of weeks.
Robin Probyn January 1st, 2013 03:17 AM
Are you sure about those prices.. Ive ordered the Sony USB 3 from B&H $350 about £215.. and i bought the sonnet from B&H.. I think it was less than the Sony USB 3 reader..??
David Dwyer January 1st, 2013 09:22 AM
Have you got a link?
I can only connect via USB or eSATA.
Robin Probyn January 1st, 2013 11:37 AM
http://www.bhphotovideo.com/c/product/905532-REG/Sony_sbac_us20_USB_3_0_SxS_Memory.html
David Dwyer January 1st, 2013 03:57 PM
Originally Posted by Robin Probyn (Post 1770548)
Sorry meant for the Sonnet reader as the Sony one isn't available yet.
Robin Probyn January 2nd, 2013 07:25 AM
Interesting the echo express pro is available $170 .. but the echo express says discontinued..
Sonnet express| B&H Photo Video
But anyway the pro will work.. only thing is a while back mac OS 10.8.2 update broke the driver for SXS card use.. dont know if that ever got resolved.. just to put another spanker in your plans..
David Dwyer January 2nd, 2013 10:02 AM
That'll be over TB which I don't have as I'm a Windows user and not Mac. Waiting for the TB ports to come to Windows later this year. I can only use USB 2/3 and eSATA
Robin Probyn January 2nd, 2013 07:25 PM
ah ok .. sorry didnt see that you are on windows.. I guess you could use the camera USB2 port to down load until the Sony USB3 one is available.. got an email from B&H they are still waiting for supply..
Alister Chapman January 3rd, 2013 07:23 AM
A possible option might be to hire something like a Nexto DI NVS2500.
David Dwyer January 3rd, 2013 12:31 PM
No can do with that as the camera will be sealed in a bag like Alister suggested to prevent condensation
Yeah I thought about that but would I need the UDF version because I'm recording at the higher rate? Also read that the UDF won't work with Windows
Robin Probyn January 3rd, 2013 09:43 PM
Sounds like you need to buy a mac :)
David Dwyer January 4th, 2013 10:18 AM
Not a Apple user, never will be. Have a total dislike for the Apple products. Also seeing a lot of FC users are changing to PP on either Mac or a PC.
Also I have ordered the MXM Express USB2 reader for £20. Hoping it just works although a little slow at 40MB/s Max.
Alister Chapman January 4th, 2013 10:32 AM
Yes you would need the UDF version for the 50Mb/s material.
UDF works on a PC. If it didn't you wouldn't be able to read the SxS cards, XDCAM discs, BluRay's or DVD's. UDF is the format used for most optical discs including DVD and BluRay. Nothing special about UDF. It was originally designed for sequential writing and as a result isn't as fast for random access writing and reading as FAT, NTFS etc so isn't normally used for hard drives, but you can format hard drives using UDF.
David Dwyer January 4th, 2013 10:38 AM
Ah just read from the NVS2525 UDF:
Limitation
OS compatibility
- Both internal and external hard drives are formatted in UDF format
- External hard drive that is formatted in UDF does not work with Windows OS but works fine with MAC OS. (Earlier firmware version of V1.51)
Nexto DI - Next Generation Storage with Digital Interface
Does the 2501 support reading the UDF cards but writes the data onto the Internal FAT HDD?
Alister Chapman January 5th, 2013 05:32 AM
I'm not sure whether you can use the 2501 with 50Mb/s cards. In theory, if the file sizes are less than 4GB then you should be able to write the data to a FAT drive, it would only be with longer takes and shots that create files bigger than 4GB that you would have a problem. The new firmware versions allow you to format the drive using ExFAT which does not have a file size limit. The PMW-500 is listed as being supported by the non UDF 2500 and 2501, but I've never actually tried a UDF card with my 2500. After all you can copy from a UDF SxS card to an NTFS or Mac OS formatted drive, so the destination doesn't have to be UDF. I'll have an F5 in the week so I'll create some UDF files and see what happens.
If you upgrade the NVS2525 Firmware beyond version 1.51 then the UDF drives can be read by Windows without issue. The windows problem only exists with drives formatted with firmware version 1.5 or earlier.
Dave Sperling January 6th, 2013 03:49 PM
My Nexto2500 (currently on firmware v1.52) gives an error message if I try to copy a UDF format SxS card.
The UDF cards read just fine with the Sony USB2 reader (SBAC-US10) connected to a pc, and also read properly in the expresscard slots of both my pc laptops.
One of my big complaints is the way computer manufacturers (even Sony) seem to have abandoned the expresscard slot. If you can still find one, I'd highly recommend picking up a closeout laptop that still has the slot. (I ended up with an Asus B53S with Expresscard, USB3 and eSATA -- for under 1K -- that transfers a full 32GB SxS1a card to an inexpensive external USB3 drive in under 5 minutes.) When travelling I really don't like having to carry the extra card reader and worry about power and all the extra cables to worry about.
David Dwyer January 6th, 2013 03:56 PM
Dave funny you should say that about buying a laptop with a EC slot as I've just purchased a Dell Precision M6700! So I'm hoping it will handle 50Mbps footage and read my SXS cards without any problems.
Purchased it from the Dell Outlet store for £1200.
Spec:
Processor: Intel® Core™ i7-3720QM (2.60GHz Turbo, 6MB, Upgradable to Intel® vPro™ technology)
Display : 17.3 Inch UltraSharp FHD(1920x1080) Wide View Anti-Glare LED-backlit Premium Panel Guarantee
16 GB Dual Channel DDR3 1866MHz Memory (2 DIMMs)
Graphics: NVIDIA Quadro K3000M with 2 GB GDDR5
Also have a Samsung 120GB SSD and 512GB SSD to put into the machine.
Dave Sperling January 6th, 2013 06:11 PM
Yes, you should be able to scream through your transfers with that one!
(Make sure to check the Sony docs for the proper order in which you need to install the SxS/UDF drivers.)
David Dwyer February 8th, 2013 07:58 AM
Well the PMW-200 and Laptop went very well. Needed another day to get used to the PMW-200 as that was my first event filming with it.
If anyone is interested the show goes out on Motors TV UK/France tonight at 22:00
