PMW-350 flash colours
Hi all,
Weird topic-title but OK. I'm currently having an issue with blue flashes and my PMW-350 (with standard lens). Check the overheated colours of the blue flashes of the fire trucks in e.g. this videoitem: My EX1R gives me overall more saturated colours but doesn't have this issue. The colours the PMW-350 produces with this picture profile created by Alister are OK and look quite natural. But those flashes keep annoying me. Is this a picture profile issue and if so, which value should I change? Any help is appreciated. Thanks. Gabor |
Re: PMW-350 flash colours
The only thing I would suggest is to reduce your overall saturation level a bit. It looks like the piece was shot in the evening, so it's not really all that surprising to see the blue flashing lights illuminating things blue.
I've been seeing this in other forums. There's something about blue LED's that is very non-linear.
The direct light coming from the red brake lights and the blue strobes appear equally strong even though the blue strobe device has much higher intensity. This is because the direct blue light is overexposed. The reflections of light are not overexposed however, so the reflected blue appears much stronger on the faces. Those are the only two colors of direct light of any notable prominence. If somehow the reflected intensity of the blue was reduced to appear more balanced when compared to the reflected intensity of the lower powered red, that would not properly represent the scene.
| All times are GMT -6. The time now is 11:16 AM. |
