-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   Powering the Sony sxs card reader by a Swit battery (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/507377-powering-sony-sxs-card-reader-swit-battery.html)
Brian Cassar April 29th, 2012 10:20 AM
Has anyone powered the Sony sxs card reader by a Swit 96Whr battery? I need to offload footage without the need of an ac power supply. I was thinking of buying the Dolgin accessory that helps you to use the Sony EX batteries to power the card reader when I realized that I can easily power it up using the large Swit batteries.
However my concern is that the battery outputs around 16.5volts whilst the ac power adaptor of the reader outputs a 12volt output. I know that some electronics have a range of acceptable voltages but I am not on a mood of risking at the moment.
Hence I would like to see whether someone took the plunge and did it ....and the reader survived!
Les Wilson April 29th, 2012 06:44 PM
Re: Powering the Sony sxs card reader by a Swit battery
Works fine with the Swit 8U62 battery
Brian Cassar April 29th, 2012 10:11 PM
Thanks Les...that's what I wanted to hear!
